Old 05-16-2003, 10:59 AM   #1
DarkRaptor42
DarkRaptor42 is an unknown quantity at this point
Question z32 5 Lug swap?
Hi fellas
I have access to a z32 for parts and since Im getting the brakes off of it already, I was wondering if you can use the parts off of it for the 5 lug swap also. This would be really cool instead of getting the rotors redrilled for my 4 lugs. If anyone knows of any info on this it be awesome.
My cars a 1990 s13. thanks
04 WRX STi
90 Sil- Camino
R.I.P. AE86 20v MS
R.I.P. KA-T
www.209forums.com
DarkRaptor42 is offline   Reply With Quote
Old 05-16-2003, 11:02 AM   #2
Dousan_PG
Dousan_PG's Avatar
ACK research
but
for 5 lug
ONLY can use
NA (non turbo) Z32 REAR hubs
front hubs do not work
NO TwinTurbo (TT) parts (hub wise)
front spindles DO NOT work on 240sx
only rear hubs (na)
rear spindle (na)
brakes (ebrake cable modification is required)
you can also use rear Z32NA spindle (maybe tt works? dont know) but you need a z32 rear shock or lower part of shock on your coilover. ~8 lbs unsprung weight
eh.
Aaron
Pink GodziRa
Old 05-16-2003, 11:41 AM   #3
DarkRaptor42
well the rear works eh but not the front, that sucks big time
oh well
guess Im gonna need s14 hubs then
04 WRX STi
90 Sil- Camino
R.I.P. AE86 20v MS
R.I.P. KA-T
www.209forums.com
Old 07-09-2003, 09:43 PM   #4
Driving-In-The-Rain
Driving-In-The-Rain is an unknown quantity at this point
dousan36, does the year of the z32 matter...i've researched the swap for a while and i keep getting different answers for what parts are can be used for the swap.
If what your saying is correct, does that mean i have to have the front hubs from a 92 300z pressed into my 95 s14 spindles?
"Theres not a problem that i cant fix.........because i can do it in the mix. and if your man gives you trouble you just move out on the double and you dont let it trouble your brain, cuz away goes trouble down the drain. i said away goes trouble down the drain."
Driving-In-The-Rain is offline   Reply With Quote
Old 07-09-2003, 09:45 PM   #5
Dousan_PG
Dousan_PG's Avatar
stay.....um...91 up for sure rears! remember ONLY NA (non-turbo) z32!! very important!
no you cant use fronts at all.
Aaron
Pink GodziRa
Old 07-09-2003, 11:34 PM   #6
meme
meme is making a name for him/her selfmeme is making a name for him/her self
if you need to get the rear hubs off the z32 uprights; remove the e-brake assembly first(the fat nut above the 4 smaller one). i spent about 20min trying to remove the hubs!!!!
good luck..
meme is offline   Reply With Quote
Old 07-10-2003, 12:08 AM   #7
sileighty89
sileighty89 is an unknown quantity at this point
s13
the tt z32 rear spindles will work on a s13.
sileighty89 is offline   Reply With Quote
Old 07-10-2003, 01:16 PM   #8
ghostchild316
ghostchild316's Avatar
ghostchild316 is an unknown quantity at this point
Everyone talks about the front calipers/sizes whatever.
What about the rear?did all z32s have the same size calipers/rotor?
ghostchild316 is offline   Reply With Quote
Old 07-10-2003, 01:40 PM   #9
ultraprince
I like APC
ultraprince is an unknown quantity at this point
Send a message via AIM to ultraprince
the rear is a little more tricky then the front. the rear you have to modify the e brake to make it work. I will do it when the bugs are all worked out of the projectsilvia e brake kit. but for now the front with stock rears work wonderfully.
APC OWNZ ME!!!
ultraprince is offline   Reply With Quote
Old 07-11-2003, 09:22 AM   #10
FoCaL
FoCaL is an unknown quantity at this point
Send a message via MSN to FoCaL
Any year Z32 will work, they are all have the same brakes and hubs. The Z32TT has different spindles than the NA but it still should work, just and extra mount for HICAS.
Regards
FoCaL is offline   Reply With Quote
