Old 07-15-2003, 12:01 AM   #1
kendot240
kendot240 is an unknown quantity at this point
SR Coolant leaking help!!!
OK I pulled my car out of the garage yesterday when I got out of the car to go back and shut the garage I noticed a trail of drips going down my driveway. I pulled it rite back into the garage and jacked it up to find out that there was coolant leaking from where the tranny and the engine connect (I'm not sure of what that is called). Can somebody please tell me what's going on with my car and why it's leaking coolant!! I'm freaking out!!!!!!!
kendot240 is offline   Reply With Quote
Old 07-15-2003, 07:38 AM   #2
uiuc240
uiuc240's Avatar
uiuc240 is an unknown quantity at this point
Send a message via AIM to uiuc240
one of the hoses back at the rear of the block is not securly connected. have fun! you will have to do some hand-gymnastics to get that back together. those are the biggest PITA.
Eric
2002 Mazda Protege5
1989 S13 w/SR20DET (sold)
uiuc240 is offline   Reply With Quote
Old 07-15-2003, 09:50 AM   #3
MorganS13
MorganS13 is an unknown quantity at this point
i had coolant leaking from around the same area and it was my water pump going bad. the fluid just worked its way back and dripped off right there. feel around under your water pump and if you feel any coolant you have your problem.
MorganS13 is offline   Reply With Quote
Old 07-15-2003, 10:51 AM   #4
LanceS13
AutoX Junkie
LanceS13 is making a name for him/her selfLanceS13 is making a name for him/her self
I hope I'm not insulting your intelligence, but make sure it is in fact coolant. That location sounds awfully like the A/C evaporator core condensate drain.
LanceS13 is offline   Reply With Quote
Old 07-15-2003, 12:08 PM   #5
Kid Zelda
Kid Zelda is an unknown quantity at this point
Send a message via AIM to Kid Zelda
It could be the coolant hoses on the back on the engine, crack or busted,or where those hoses connect to the firewall to the heatcore. Or it might even be a busted heater core, which does happen.
if it's coolant, and it's coming from back there, it has to be one of these things, take a look and try to figure it out.
Kid Zelda is offline   Reply With Quote
Old 07-15-2003, 05:18 PM   #6
kendot240
it is definately coolant especially considering the fact I took the AC out. Thanks for all the replies I will check it out.
