Old 07-15-2003, 12:05 AM   #1
90240sr
90240sr is an unknown quantity at this point
Question sr20 water pump
i have a clicking/squeeling noise that sounds like it is coming from my waterpump. i am just finishing my swap i was going to drive to california from washington which is 1200 miles. i was wondering if the car will make it and then will chabge it when i get down their. i have a new radiator and a 14 inch electric fan so i think it should stay cool. Just wondering what you guys thought?
90240sr is offline   Reply With Quote
Old 07-15-2003, 08:06 AM   #2
uiuc240
uiuc240's Avatar
uiuc240 is an unknown quantity at this point
Send a message via AIM to uiuc240
how long have you had the motor? how many miles have you put on it with the pump sounding like this? if you just got it and it sounds like this, i would replace it BEFORE the trip. but if you've been driving it for a year, don't worry.
Eric
2002 Mazda Protege5
1989 S13 w/SR20DET (sold)
uiuc240 is offline   Reply With Quote
Old 07-15-2003, 10:39 AM   #3
90240sr
i am just getting the motr. i havent even drove it yet just about to finsih the swap.
Old 07-15-2003, 11:22 AM   #4
uiuc240
uiuc240's Avatar
then i wouldn't recommend taking that chance. if you know it's the water pump, take the pump out and inspect it for damage. are the fins broken? does it spin easily? does it have excessive play?
Eric
2002 Mazda Protege5
Old 07-15-2003, 11:39 AM   #5
90240sr
i will go check it out and find out what condition it is in.
Old 07-15-2003, 12:54 PM   #6
Kid Zelda
Kid Zelda is an unknown quantity at this point
Send a message via AIM to Kid Zelda
It's not uncommon for an sr (espically red top) to come with a bad water pump.
So, drian all the coolant, remove the fan and shroud and all the belts, and then remove the water pump. It will have liquid gasket, so you may want to scrap the edges of it with a scraper, so it'll come out easier.
Inspect the pump for rust or corroded vanes on the assembly, check to see how free it spinds and how much free play it has.
Kid Zelda is offline   Reply With Quote
Old 07-15-2003, 02:27 PM   #7
90240sr
i will probably get my *** kicked for asking this but i will anywhay. What does the waterpump actually do? I know it cools the engine but what part of the engine and how?
Old 07-15-2003, 03:19 PM   #8
Kid Zelda
hehe, its cool
check this simple answer
what does your heart do ? Pump, pump blood, to what, through your system, when your system gets happy it pumps more to a specfic area
Unless you're like me-- heartless muthanukka
more tech' answer
The water pump uses centrifugal force to send fluid to the outside while it spins, causing fluid to be drawn from the center continuously. The inlet to the pump is located near the center so that fluid returning from the radiator hits the pump vanes. The pump vanes fling the fluid to the outside of the pump, where it can enter the engine.
The fluid leaving the pump flows first through the engine block and cylinder head, then radiator and back to the pump.
