Old 07-13-2003, 09:19 AM   #1
drifties151
drifties151's Avatar
drifties151 is an unknown quantity at this point
Send a message via AIM to drifties151
Question lighting problems
ok, here's the situtation and it has me stumped... my s14 is coming outta the shop soon and i changed all my bulbs. my directionals work but my hazards dont. i have no idea why this happened. is there a seperate fuse for hazards that i dont know about? any help would be appreciated, thanks!
-terry
1995 240sx
drifties151 is offline   Reply With Quote
Old 07-15-2003, 08:57 PM   #2
old_s13
old_s13's Avatar
old_s13 is an unknown quantity at this point
Either your switch is bad or your flasher is not operating correctly. Sounds more like a switch or wiring issue.
old_s13 is offline   Reply With Quote
Old 07-15-2003, 10:23 PM   #3
vietbz
vietbz is an unknown quantity at this point
Yea the hazard lights have a seperate fuse, its in the fuse box located in the driver side kick panel (not sure how to describe the location any better) give it a check, I'm pretty sure that's what's wrong.
vietbz is offline   Reply With Quote
Old 07-17-2003, 10:19 AM   #4
Startours7
Startours7 is an unknown quantity at this point
If i'ts not the fuse(witch it more times then not is) remember switches go before wires in most cases. take a multi meter and see if you have power after the switch. I you have 12v before the switch but not after, that is your problem. Good luck
Startours7 is offline   Reply With Quote
