Old 06-09-2010, 08:23 PM   #1
burtonrida133
burtonrida133's Avatar
burtonrida133 has a spectacular aura aboutburtonrida133 has a spectacular aura aboutburtonrida133 has a spectacular aura aboutburtonrida133 has a spectacular aura aboutburtonrida133 has a spectacular aura aboutburtonrida133 has a spectacular aura about
Send a message via AIM to burtonrida133
Fuel cut when i accelerate hard? HELP FIX!?!?
i have an sr20det blacktop in my zenki, i played with the boost and had it up for a while and then turned it down when i left for college, im back in town and its been fuel cutting when i accelerate hard at around 4500 rpm...and im only running 4 psi right now, does anyone know what the issue might be??
zenki for life
burtonrida133 is offline   Reply With Quote
Old 06-09-2010, 09:35 PM   #2
cotbu
cotbu's Avatar
external wastegate or adjustable? if not check for boostleaks, ecu for codes just basic maintenance. because it can be a number of things including dirty\clogged fuel filter, failing fuel pump, timing, injectors, etc. you get me. treat the car likes it's been sitting for a year and just check all of the inexpensive things from plugs to whatever cost less then 20$ report back and let us know if there's a difference. I would check for codes, timing, tps, mafs and cts voltages and fuel pressure also oil pressure just because.
Old 06-10-2010, 08:09 AM   #3
burtonrida133
alright thanks, i will let you know...
zenki for life
Old 06-11-2010, 06:27 AM   #4
burtonrida133
it ended up being a leak in my intercooler hot pipe...fml. got it fixed but had to weld the hole shut
zenki for life
