Old 07-19-2003, 06:58 PM   #1
Heartwork
Heartwork's Avatar
Heartwork is an unknown quantity at this point
Torque specs on Z32 caliper bolts??
can someone tell me the correct torque specs for the 1991 TT z32 30mm Aluminum Caliper bolts?
thanks...
Heartwork is offline   Reply With Quote
Old 07-19-2003, 07:36 PM   #2
240racer
240racer's Avatar
240racer is an unknown quantity at this point
Maybe I'm wierd but I've never used a torque wrench on brake caliper bolts. Since the caliper is Aluminum I understand your concern, but I wouldn't worry about tightening them pretty tight. I don't know the specs, but typed in z32 caliper torque specs in google and this is what I found http://www.cautioncreativity.com/briand/Q45%20Brake.htm it says 75ft/lbs. It's the Q45 upgrade, but whatever.
Adam
'89 coupe KA24DE+T
14.1 @ 104 MPH
'88 Celica All-Trac turbo
stock, but no more ecu codes!!
240racer is offline   Reply With Quote
Old 07-20-2003, 02:21 AM   #3
Heartwork
Heartwork's Avatar
i forgot to note that i needed the torque specs on the bolts holding the calipers itself, not the bolt that bolts to the knuckle...
Old 07-20-2003, 03:17 PM   #4
THX1138
THX1138 is an unknown quantity at this point
So you're talking about the bolts that hold the caliper halves together? Apparently those specs aren't published, the 300ZX FSM doesn't describe how to disassemble/rebuild the caliper body. There's a thread on FreshAlloy in the 240SX Advanced forum that's mentioned this in the last week or so (sorry, not gonna stick a link in here, I'm at home on slow-azz dialup). Folks in that thread have mentioned 40-45 lb/ft as a good value to use.
THX1138 is offline   Reply With Quote
Old 07-21-2003, 08:20 AM   #5
TNathe
TNathe is an unknown quantity at this point
Tight is tight, too tight is broken.
~Tyler
TNathe is offline   Reply With Quote
Old 07-21-2003, 09:01 AM   #6
Dunkee
Dunkee's Avatar
Dunkee is a glorious beacon of lightDunkee is a glorious beacon of lightDunkee is a glorious beacon of lightDunkee is a glorious beacon of lightDunkee is a glorious beacon of lightDunkee is a glorious beacon of lightDunkee is a glorious beacon of lightDunkee is a glorious beacon of lightDunkee is a glorious beacon of lightDunkee is a glorious beacon of lightDunkee is a glorious beacon of light
There's a whole write up on the Technical link on this site...by the gallery.
96 SE http://www.cardomain.com/ride/255381
Dunkee is offline   Reply With Quote
