Old 07-21-2003, 08:46 AM   #1
TNathe
TNathe is an unknown quantity at this point
Looking for advice on turbo install
My friend is hooking me up with his two turbos that came off his 1990 300ZX. I have a 1998 240SX SE and was wondering how much boost I could push with one of his stock turbos, I'm not sure of the make or model of the turbos. Also, do ya'll think it woud be worth having a custom manifold and piping made for this turbo, or should I just save and purchase a turbo kit for the KA, or better yet, do they make a manifold and piping that will work with a 300zx turbo for my application? Does anyone know if I could use the injectors and fuel pump from the 300ZX for my turbo install? Havn't done too much research on it yet, just thought I would ask ya'll 240 experts before I went on a wild goose hunt. Thanks in advanced.
~Tyler
TNathe is offline   Reply With Quote
Old 07-21-2003, 09:53 AM   #2
Kreator
Kreator's Avatar
Kreator will become famous soon enoughKreator will become famous soon enoughKreator will become famous soon enough
IIRC, the 300zx came with t3 turbos, and most "standard" manis made for ka are t3/t4 which will work with the t3. The turbos however are pretty small, so id say no more than 7-8 psi before you run out of efficiency range. The 300zx did come with the same purple injectors which are a direct swap in, but (again iirc) only 93+ models. Fuel pump is a direct swap.
кто болеет за Зенит, у того всегда стоит!
Kreator is offline   Reply With Quote
Old 07-21-2003, 10:53 AM   #3
TNathe
Thanks a lot for the info. You probably saved me a couple hours of searching on Google for that information. Preciate it bro.
~Tyler
