Boost falling off
Hey guys. I'm having trouble with setting my boost. I want to set it for 19 psi but the boost is always falling off at high rpms. It usually falls off around 6600rpm and higher.
I have a HKS adjustable wastegate actuator so I tried bypassing the boost controller and adjusting it through the wastegate and the boost drop off was even worse. I also tried playing with the gain and set gain values (Greddy Profec Spec 2) but that didn't do much. I also fixed all of the boost leaks and while this improved response, the boost still falls off. Could this be that the actuator is not good enough for the higher boost setting? My setup: Redtop SR GT2871R .64 BC Step 3 cams Greddy Profec Spec 2 |
![]() Join Date: May 2006
get your motor tune
![]() Join Date: Mar 2006
I had this problem, and it turned out to be a slice in an intercooler coupler causing a boost leak, but my fuel/spark were just fine bc I am on MAP sensor.
Check for boost leaks
Daily driven |
#6 | |
1) Boost leak (i had this and it only caused boost drop off at high RPM) 2) Wastegate flapper can't stay shut enough to hold boost
Daily driven |
#7 | |
If the wastegate flapper can't stay shut, that would be a problem with the actuator correct? I don't think the actual flapper mechanism could be bad because it is a brand new GT2871R .64. |
