Old 06-25-2010, 05:47 PM   #1
surreybc
surreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond repute
How much vacuum should there be in throttle body?
I only get 1 or 2 inches of vacuum at throttle. The aiv hose has a ton more vacuum. the egr only needs 1 or 3 inches vacuum to lift on my car.
trying to figure out why my egr valve is not lifting when i roar engine. my egr lifting abiltiy has slowly weakened until now i fail smog. Im thinking the exhaust hose going to bpt is clogged? i applied 30 inches of vacuum to egr solenoid and egr still did not lift.
surreybc is offline   Reply With Quote
Old 06-25-2010, 11:45 PM   #2
lazysk8er2
lazysk8er2's Avatar
lazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud of
not sure what kind of motor your running but at idle my sr20 reads -20 psi
also its read in negative psi not just inches for vacuum
Well i have a 95 240 and i like my cars low... But my parents don't like my wheels tilted
________________________________
lazysk8er2 is offline   Reply With Quote
Old 06-26-2010, 02:09 AM   #3
surreybc
it must depend on where you measure.
