Old 07-08-2010, 08:50 PM   #1
rebornS14
rebornS14's Avatar
rebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of light
Send a message via AIM to rebornS14
Question swapping a Kouki S14 OBDII to Zenki S14 HELP!
what's up guys. before i start this project i want to see what im getting myself into.
i have a 95 S14 with a S13 SR
and i have a 97 S14 bone stock.
i want to swap the stock KA out of the Kouki and put it in my zenki so i can build up the SR and put it in the Kouki.
since the Zenki is OBDI, what kinda problems will i run into and is there a thread thats done this that will help me? i tried search option but everything i search something i get a error.
help me make this happen.
rebornS14 is offline   Reply With Quote
Old 07-27-2010, 02:04 PM   #2
rebornS14
rebornS14's Avatar
ok since no one can answer that. how about this:
if i swap the motor and use a ZENKI (95-96) ECU with the 97 OBDII motor, would that work without a check engine light?
my main concern is the CEL cause i want it to be a perfectly smog legal car. not planning on modding this one. someones got to know this.
Old 07-27-2010, 02:16 PM   #3
XeroX
XeroX's Avatar
XeroX is an unknown quantity at this point
I might be wrong, but im pretty sure a 95+ is OBDII.
Regardless, your going to have to pair up the ECU with the correct production date.
95 = Different ECU
96 = Different ECU
96 = Different ECU
So your going to have to find the right ecu for whatever your KA is out of or your going to get a CEL.
XeroX is offline   Reply With Quote
Old 07-27-2010, 02:20 PM   #4
XeroX
XeroX's Avatar
In theory I see were your going with this but the thing is that ther harness pin locations change for certain sensors (if i remember correctly). So i dont think this will just pnp without a code...
I am not 100% just trying to provide my input.
Old 07-29-2010, 11:35 AM   #5
LigouriRd
LigouriRd's Avatar
LigouriRd will become famous soon enoughLigouriRd will become famous soon enoughLigouriRd will become famous soon enough
I just wanna get this straight you are trying to convert the 95 back to a KA and have it smog legal right? The '97 is going to eventually get the sr.
IMO your best bet would be to swap the '97 Ka, engine harness and ecu to the '95 if you want to pass emissions. There are subtle differences between the '95, '96, and '97/98 harnesses and ecu's keeping them all matching the engine would be your best bet. I am not sure how smog will react to the ecu not matching the car year but mabye your '95 does not have an OBD port and they will not scan it. There are some '95s that are OBDI and there are some that are OBDII, its a transition year, wierd.
Frankly, you are better off keeping the kouki as your smoggable car. If you want the kouki look, swap body panels.
'96 Nissan 240SX KA-T ─ '05 Grand Cherokee Laredo 4x2─'85 Nighthawk
LigouriRd is offline   Reply With Quote
