Old 08-10-2010, 07:15 PM   #1
Steve Lloyd
Steve Lloyd's Avatar
Steve Lloyd is an unknown quantity at this point
Need some S14 SR20DET help!!!!!!
Steve Lloyd is offline   Reply With Quote
Old 08-10-2010, 07:48 PM   #2
JDMwannaBE
JDMwannaBE's Avatar
JDMwannaBE is on a distinguished road
all your fuses/relays good? have you gone through the new wiring you did? did you do any soldering? if so you may have a bad ground from it. i've had that happen before. just some suggestions.
JDMwannaBE is offline   Reply With Quote
Old 08-10-2010, 08:19 PM   #3
Sam_Well.13
Sam_Well.13 is an unknown quantity at this point
staring at your avatar got me blanked out. sorry im no help =/ lol
nice boobs on that chick though.
Sam_Well.13 is offline   Reply With Quote
Old 08-10-2010, 08:40 PM   #4
Steve Lloyd
The only soldering I did was on the MAF signal and ground wire. The relays work if I manually ground the wires that the ECU should be grounding, all the grounds seem to be fine, power gets to the ECU, it's just the 2 wires that are supposed to switch to ground from the ECU to trigger the relays aren't switching over anymore.
Old 08-10-2010, 09:24 PM   #5
Slidin' Sam
Slidin' Sam's Avatar
Slidin' Sam is an unknown quantity at this point
Try disconnecting your battery, then unplugging your ECU. Wait a minute, then plug the ECU back in, then hook up the batter again. Then try to start it and see what happens. Sometimes the ECU just needs to be reset. Make sure all your connectors are good and tight too!
Slidin' Sam is offline   Reply With Quote
Old 08-10-2010, 09:43 PM   #6
JDMwannaBE
JDMwannaBE's Avatar
True statement
