Old 08-03-2003, 03:41 PM   #1
turboex
turboex is an unknown quantity at this point
Check engine light no work on sr20det?
Ok i followed the wiring just as srswap.com says and still no check engine light, i have yet to see it light up. I know the ecu requires the wire from the light to run to it, but i can only find the wire on the car side. its a red wire according to my fsm but what pin does it go to on the sr20det redtop ecu? thanks
1992 240sx SE
s13 silvia frontend conversion
SR20DET, custom top mount turbo manifold, Precision SC61 turbo, blitz bov, HKS intercooler, Tial 38mm wastegate, tenzo-r shu-4's, ton of other shit. with clean new paint!
turboex is offline   Reply With Quote
Old 08-03-2003, 08:07 PM   #2
Racer X
Racer X is an unknown quantity at this point
Send a message via AIM to Racer X Send a message via Yahoo to Racer X
mines dosent work either if that makes you feel better. but i dont think sr ecu's have a diagnostic function. not sure but i never seen anyother sr cars have a chech engine light.
Twin67 ls1/awd in the works
Racer X is offline   Reply With Quote
Old 08-03-2003, 08:15 PM   #3
turboex
good point, i have never realy heard anyone ask about engine codes on an ecu, so maybe the dont have a mil light. Hum..
1992 240sx SE
Old 08-04-2003, 01:49 AM   #4
DudeYourSoOOJDM
DudeYourSoOOJDM's Avatar
DudeYourSoOOJDM has much to be proud ofDudeYourSoOOJDM has much to be proud ofDudeYourSoOOJDM has much to be proud ofDudeYourSoOOJDM has much to be proud ofDudeYourSoOOJDM has much to be proud ofDudeYourSoOOJDM has much to be proud ofDudeYourSoOOJDM has much to be proud ofDudeYourSoOOJDM has much to be proud ofDudeYourSoOOJDM has much to be proud ofDudeYourSoOOJDM has much to be proud ofDudeYourSoOOJDM has much to be proud of
Send a message via AIM to DudeYourSoOOJDM
There is no CEL for SR......run the codes off of the ECU.
DudeYourSoOOJDM is offline   Reply With Quote
Old 08-04-2003, 04:30 AM   #5
turboex
hum how do i do this?
1992 240sx SE
Old 08-04-2003, 08:07 AM   #6
PAnut240
PAnut240 is an unknown quantity at this point
Send a message via AIM to PAnut240 Send a message via Yahoo to PAnut240
SR
I would say do a search. I know this has been covered on this page before. If you can't find it Search Google, and you should be able to find the code page for sr's. If I had mine with me I would give the site to you. I'll check later.
Jim
'89 Fastback  SR20det; Greddy Profec B II boost controller. HKS 262 CAMS. Greddy Radiator,pulleys,oilfilter relocation kit,boost gauge, rockerarm stoppers,intake manifold. Nismo Fuel Press Reg. Ferra duel Valvesprings, ti retainers. East Bear headlight conversion. Type X tail lights. Tien Suspension, Tanabe race exhaust.  GT 16" rims, Walbro high Pressure fuel Pump,  7pt rollcage. HKS BOV. Mandril Exhaust Man. GTR FMIC. BeeR Valve cover. JE Pistons and Eagle Rods.
PAnut240 is offline   Reply With Quote
Old 08-04-2003, 08:51 AM   #7
old_s13
old_s13's Avatar
old_s13 is an unknown quantity at this point
"check engine" is a light mostly for emissions. sure, you can get other error codes off of the ECU but in US cars, the concept of check-engine has always been to scare customers into running back to the dealership thinking their car needs serious work, when its really just EGR or something silly.
Check engine = crap. Pop your hood, check to see your motor is still ther = done. Congratulations, you checked your motor.
- Mike
old_s13 is offline   Reply With Quote
Old 08-06-2003, 08:57 PM   #8
rednerd
rednerd is an unknown quantity at this point
For anyone who cares , a Snap-On Mt2500 scan tool works with the SR computer. I don't know about diagnostics, but it will pull, and clear codes. The monitor function also works. Just make sure you have the wires that connect the engine harness to the body harness wired properly.
Ohh, I use a 1993 DOHC 240sx vin on the scan tool.
Jon
rednerd is offline   Reply With Quote
