Old 08-12-2010, 07:32 PM   #1
T3X_S13
T3X_S13's Avatar
T3X_S13 is an unknown quantity at this point
s13 se model window problem!!!
Okay i been searching google trying to find someone with the same problem but no luck,i got a 92 240sx se model hatch and my drivers side window jus recently stoped working(passenger still works).My fuses and relays are good,i also tryed swapping out the window switch but nothing,i hear a clicking noise from a black box behind door panel.The window will come down sometimes but will not come back up.If anyone could help i would greatly apreciate it. Thanks
T3X_S13 is offline   Reply With Quote
Old 08-12-2010, 07:39 PM   #2
94spitfire91
94spitfire91's Avatar
94spitfire91 is an unknown quantity at this point
window motor might not be getting the power it needs if you say clicking but if your sure the is enough power circulating in there than replace the motor. A used one you can get for 15 bucks thats what i would do
94spitfire91 is offline   Reply With Quote
Old 08-12-2010, 07:44 PM   #3
T3X_S13
T3X_S13's Avatar
yeah am trying to avoid replacing it lol but somedays it will work for about 3 or 4 times then will stop so i know the regulator is still good,i was thinking there might be a wire short but i didnt see any behind the door panel?
Old 08-12-2010, 07:49 PM   #4
drift freaq
R.I.P. Aya, always love
drift freaq's Avatar
Trader Rating: (215)
Feedback Score: 215 reviews
change out the black box. It should fix it. It does go bad and I have had to replace them before. They are not expensive to get used.
New Video
Buy my mounts!
Old 08-12-2010, 08:04 PM   #5
T3X_S13
T3X_S13's Avatar
yeah ima try an find one at a junkyard an see if it fixes it
Old 08-12-2010, 10:10 PM   #6
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
replace the amp (black box)
99.9% of the time it will solve the problem.
there is a relay in there that fails.
Old 08-12-2010, 10:24 PM   #7
Zenki_Kouki.5
Zenki_Kouki.5 is an unknown quantity at this point
^^^x2 i changed out mine like 5 times cus of that
Zenki_Kouki.5 is offline   Reply With Quote
Old 08-26-2010, 06:39 PM   #8
8Nismo9
8Nismo9's Avatar
8Nismo9 will become famous soon enough8Nismo9 will become famous soon enough8Nismo9 will become famous soon enough8Nismo9 will become famous soon enough8Nismo9 will become famous soon enough
Send a message via AIM to 8Nismo9
any other cars you can use the black box from?
Life is like a box full of shenanigans
8Nismo9 is offline   Reply With Quote
Old 08-26-2010, 06:54 PM   #9
thompsn
thompsn is an unknown quantity at this point
or the Nissan part number or where you can get them?
I can't seem to find them anywhere.
thompsn is offline   Reply With Quote
Old 08-26-2010, 07:03 PM   #10
89JDMRB20
89JDMRB20's Avatar
89JDMRB20 is an unknown quantity at this point
I had the same problem... Def the Black box...
89JDMRB20 is offline   Reply With Quote
Old 08-28-2010, 11:18 PM   #11
Mishkin_707
Mishkin_707's Avatar
Mishkin_707 is an unknown quantity at this point
also may want to check out the cable on the window regulator that pulls the window up and down on the track, mine was all messed up and it wouldn't let my my window roll up or down and sometimes it would work, so thats what you might want to check out
EDIT: the cable may be frayed.
Mishkin_707 is offline   Reply With Quote
Old 08-29-2010, 03:22 PM   #12
T3X_S13
T3X_S13's Avatar
yup it was the black box thanks guys!
Old 08-29-2010, 09:28 PM   #13
sleep
sleep's Avatar
sleep is an unknown quantity at this point
Send a message via AIM to sleep
where did you obtain the amp from?
sleep is offline   Reply With Quote
Old 08-29-2010, 09:44 PM   #14
T3X_S13
T3X_S13's Avatar
From the junkyard off another s13
