Old 03-07-2012, 12:23 AM   #1
jinesz32
jinesz32's Avatar
jinesz32 is a splendid one to beholdjinesz32 is a splendid one to beholdjinesz32 is a splendid one to beholdjinesz32 is a splendid one to beholdjinesz32 is a splendid one to beholdjinesz32 is a splendid one to beholdjinesz32 is a splendid one to beholdjinesz32 is a splendid one to beholdjinesz32 is a splendid one to beholdjinesz32 is a splendid one to beholdjinesz32 is a splendid one to behold
Send a message via AIM to jinesz32
s13 auto to 5 speed help
I haven't worked on a 240 in awhile so I'm a bit confused,
the last owner messed up the harness big time so I just went ahead and replaced all of it with a 5 SPEED harness, not an automatic harness, the only thing I did not replace was the tranny harness.
Uncut chassis harness and uncut engine harness.
I plugged everything in and the car does not start, the tranny harness seems a bit hacked up too.
I don't know if it's the same for a 5 speed harness and an automatic harness but I jumped the wires together for the nuetral safety switch and still nothing,
the starter doesn't click just the relays in the 2 fuse boxes click,
any help appreciated thanks.
jinesz32 is offline   Reply With Quote
Old 03-07-2012, 01:08 AM   #2
Houseof1817
Houseof1817 is an unknown quantity at this point
does the motor hand crank? have you checked continuity to the fuel pump?
Houseof1817 is offline   Reply With Quote
Old 03-07-2012, 11:10 PM   #3
jinesz32
jinesz32's Avatar
Found out the problem,
Clutch interlock was unplugged.
Trololol. Car runs fine now. hah.
Old 03-07-2012, 11:14 PM   #4
Darren
Darren's Avatar
Darren is an unknown quantity at this point
so that would mean there's NO difference in the auto & 5 speed engine harnesses?
Darren is offline   Reply With Quote
Old 03-08-2012, 12:25 AM   #5
jinesz32
jinesz32's Avatar
I wouldn't say there were no differences, I think it was a lot easier, I didn't have to hack my ecu wires, or jump the neutral position switch. also the wires for the auto control box isn't on there, I practically plugged it in, and started it up, the tranny harness was already hacked. But all you really need is the reverse light and speedo wires.
