Old 08-07-2003, 08:45 AM   #1
the3SecondJerk
the3SecondJerk is an unknown quantity at this point
My car turns off now but dash lights don't!
OK the SR is running full steam now. All leaks are fixed and its running correctly. I have a ground wire coming up through the wire loom on the passenger side near the altenator grounded to the body. I have the Battery grounded on the engine. But when I turn the car off the brake light goes on and stereo stays on. Even with the key out off the ignition! Do I still have ground problem?
Thanks
Dan
Drive it like you stole it.
the3SecondJerk is offline   Reply With Quote
Old 08-07-2003, 10:38 AM   #2
mbmbmb23
Zilvia Contributor
mbmbmb23's Avatar
mbmbmb23 is on the path to ruinmbmbmb23 is on the path to ruin
Is this an aftermarket stereo?? You could fix this by switching the power wire going into the stereo.
-m
mbmbmb23 is offline   Reply With Quote
Old 08-07-2003, 12:59 PM   #3
the3SecondJerk
I fixed it by removing a 10a fuse in the battery side fuse box label ENG. CONT. Hopefully this doesn't wreck anything!
