Old 09-02-2010, 10:14 PM   #1
240sx1234
240sx1234 is an unknown quantity at this point
s14 My S14 (day 1- present) beware of pictures
If this thread needs to be move,let me know and do it.I feel like this is the best place though. I want to show my 240sx from when I first got it to all the modifications it has gone through. I will post problems I run into and how I solved them so the next person does not have the same problem
Info:1995 Nissan 240sx SE 121XXX Miles
What it had:bad oil leak,ngk spark plug wires,lightweight flywheel,ebay stage 2 clutch,window tint everything except windshield,couple cracks in the windshield,ebay short shifter,hid's
How the car was when I got it:
Had the maintenance done on it,leaks are fixed and car is running great.
First thing to go was the exhaust: (for sale)
HKS Hi-power exhaust
ran the crap out of my tires and this is what happened,got 4 brand new fuzion vri's
rockford fosgate wiring kit and amp,12" apline type r,and a custom box my friend built for me
got 123456 miles on my car(second car to do it in)
had the chips in the windshield fixed by some random guy at a gas station for $20,sketchy as no other but did a good job
driver side window amp went bad,bought a whole used door and replaced it
push button start installed
car started acting up and revved between 0 and 2k rpms,wouldnt rev above 5k,ran really rich. MAF CEL code came on,replaced the sensor and it did not fixed,turns out it was the wiring,went through it to see where it was bad,replaced some of it and the problem was solved.I need to solder them to make it a permanent fix
ISIS coilovers-some say bad things about them but they ride pretty good,installed them wrong with the preload or whatever and Im working on fixing that problem
camber from lowering the car was great, so i purchased godspeed rear upper control arms(RUCA's) and installed them
thought the bolt was too short but it just needed to be tightened and everything turned out great
bolt i thought was too short
the old camber arms
carbon fiber roof wing(used + bad idea) but looks decent,double sided tape is alright i guess
to be installed:
tanabe front sway bar
painted valve cover
random pics
240sx1234 is offline   Reply With Quote
