Old 08-14-2008, 08:44 PM   #1
josh_adnoh
josh_adnoh's Avatar
josh_adnoh is a well-known jackass
s14 ka24de running rich
its not my timing,check my codes on ecu not that ???its smelling like gas really BAD,bad fuel mileage,it got a ruff idle to and its back fireing? could it be a bad ecu?could it be my injectors?how do i check?
is it safe to run on the track running rich like that
i only got a intake,header and fart can
help me out
josh_adnoh is offline   Reply With Quote
Old 08-14-2008, 10:58 PM   #2
deadstock40
deadstock40's Avatar
deadstock40 is a glorious beacon of lightdeadstock40 is a glorious beacon of lightdeadstock40 is a glorious beacon of lightdeadstock40 is a glorious beacon of lightdeadstock40 is a glorious beacon of lightdeadstock40 is a glorious beacon of lightdeadstock40 is a glorious beacon of lightdeadstock40 is a glorious beacon of lightdeadstock40 is a glorious beacon of lightdeadstock40 is a glorious beacon of lightdeadstock40 is a glorious beacon of light
might be bad injectors or spark plugs.
deadstock40 is offline   Reply With Quote
Old 08-14-2008, 11:15 PM   #3
awesomenick
awesomenick's Avatar
Trader Rating: (33)
awesomenick is close to perfectionawesomenick is close to perfectionawesomenick is close to perfectionawesomenick is close to perfectionawesomenick is close to perfectionawesomenick is close to perfectionawesomenick is close to perfectionawesomenick is close to perfectionawesomenick is close to perfectionawesomenick is close to perfectionawesomenick is close to perfection
Feedback Score: 33 reviews
Spark plugs/ wires.
Coil.
Injectors/ O rings.
Coolant temp sensor.
Edit: Oh yeah. Does it smell like it's running rich, or does it smell like raw fuel? How do you know it's running rich and not just leaking fuel?
awesomenick is offline   Reply With Quote
Old 08-14-2008, 11:16 PM   #4
Rnz520
Rnz520's Avatar
Rnz520 has much to be proud ofRnz520 has much to be proud ofRnz520 has much to be proud ofRnz520 has much to be proud ofRnz520 has much to be proud ofRnz520 has much to be proud ofRnz520 has much to be proud ofRnz520 has much to be proud ofRnz520 has much to be proud ofRnz520 has much to be proud ofRnz520 has much to be proud of
Send a message via AIM to Rnz520
or the O so dreaded bad MAF
*93 240sx:KA-T, FLTA-2s, MR TR, Greddy F&R bars, Greddy gauges, Cusco brace, etc
Rnz520 is offline   Reply With Quote
Old 08-14-2008, 11:44 PM   #5
nvstyles
nvstyles's Avatar
nvstyles will become famous soon enoughnvstyles will become famous soon enoughnvstyles will become famous soon enoughnvstyles will become famous soon enoughnvstyles will become famous soon enough
i got the same problem on my sohc. everytime itouch the maf wire my idle stumbles and smells like raw gas. cleaned damn near every electrical compnent too. bad maf? or bad wire to the maf plug?
nvstyles is offline   Reply With Quote
Old 08-15-2008, 08:43 AM   #6
DriftHappy
DriftHappy's Avatar
DriftHappy is an unknown quantity at this point
I'm having a similiar issue with my KA24DE and I have replaced numerous things in the quest to figure it out. In a matter of fact the #1 cylinder randomly quit firing all together. I put new plugs, plug wires, cap, rotor, & O2 sensor in it. That seemed to take care of the #1 cylinder not firing. I also swapped the distributor & injectors with other used ones I had laying around and also advanced the timing as much as possible. I also had to cut the freakin cat off because it was clogged. Still rich as hell, almost not drivable. I'm running out of ideas. I have a spare ECU laying around. I'm going to try it tonight. If that doesn't help I can only think of the Coolant Temp & MAF. I'll try those next.
DriftHappy is offline   Reply With Quote
Old 08-15-2008, 08:48 AM   #7
beeracing s14
beeracing s14's Avatar
beeracing s14 is a glorious beacon of lightbeeracing s14 is a glorious beacon of lightbeeracing s14 is a glorious beacon of lightbeeracing s14 is a glorious beacon of lightbeeracing s14 is a glorious beacon of lightbeeracing s14 is a glorious beacon of lightbeeracing s14 is a glorious beacon of lightbeeracing s14 is a glorious beacon of lightbeeracing s14 is a glorious beacon of lightbeeracing s14 is a glorious beacon of lightbeeracing s14 is a glorious beacon of light
id say time to get an SR20DET period
beeracing s14 is offline   Reply With Quote
Old 08-15-2008, 09:07 AM   #8
josh_adnoh
josh_adnoh's Avatar
it smells like burnt gas coming out of the exhaust,bad gas mileage,back fireing? and if it was just leaking gas it would leave a trail of gas
Old 09-15-2010, 10:09 AM   #9
foxyfied
foxyfied is an unknown quantity at this point
hey i dont know what exactly setups you have but just something to keep in mind i know we had this problem with two of are ka's if you delete your egr system it ads about 7% fuel jto idle not sure how much while driving so if you did delete your egr you need to get something to manage your fuel hope this helps you guys
foxyfied is offline   Reply With Quote
