Old 09-17-2010, 12:06 AM   #1
kaidohms
kaidohms is an unknown quantity at this point
s13 sway bar bracket loose bolts...help..
this happened to me on several occasions. i would notice the bolts being loose but not out of the hole, simply chilling. so i used loctite and did work on the bolts..after maybe 100+ miles of driving, im guessing the vibration broke them loose, again.
does this happen to anyone else? any remedies? any way to shut them up? thanks.
edit: front sway bar
kaidohms is offline   Reply With Quote
Old 09-17-2010, 12:16 AM   #2
Sileighty_85
Sileighty_85's Avatar
New bolt+ Lock washers+ Loctight
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 09-17-2010, 01:05 AM   #3
Tokona-x
Tokona-x's Avatar
Trader Rating: (140)
Tokona-x is an unknown quantity at this point
Feedback Score: 140 reviews
Send a message via Yahoo to Tokona-x
+1 for that combo .....and also make sure to tighten that mug! the hell up!
I have five speed bolts if you need any
Custom 2+2 E brake Cable brackets sold here!!!!!
Tokona-x is offline   Reply With Quote
Old 09-17-2010, 07:21 AM   #4
projectRDM
projectRDM's Avatar
Not too tight, the endlinks should be tightened with the car on the ground, loaded, and only to the point the bushings begin to flex a little. Overtightening will destroy the bushings.
FORMERLY R240NA
