Old 09-22-2010, 05:04 PM   #1
S14Driftr91
S14Driftr91's Avatar
Trader Rating: (26)
S14Driftr91 is a name known to allS14Driftr91 is a name known to allS14Driftr91 is a name known to allS14Driftr91 is a name known to allS14Driftr91 is a name known to allS14Driftr91 is a name known to allS14Driftr91 is a name known to allS14Driftr91 is a name known to allS14Driftr91 is a name known to allS14Driftr91 is a name known to allS14Driftr91 is a name known to all
Feedback Score: 26 reviews
clutch pedal has no pressure after bleeding
the first time i bled the clutch it didnt work so i went out and bought a new master cylinder, installed that and went to bleed the system again...still no pressure. now i have looked and searched and people that seemed to have this same problem are told to replace the slave cylinder ???
Should i buy a slave cylinder ? or do i possibly take the tranny off again ?? thank you for any input
www.allthingsproper.com
S14Driftr91 is offline   Reply With Quote
Old 09-22-2010, 05:22 PM   #2
brizanden
brizanden's Avatar
brizanden is an unknown quantity at this point
Send a message via AIM to brizanden
do you still have that clutch line loop? if so you gotta bleed that shit like a pro to get correct pressure back i just delt with the crap cause im stubborn and refused to remove the clutch line loop and little box.
brizanden is offline   Reply With Quote
Old 09-22-2010, 05:39 PM   #3
S14Driftr91
Trader Rating: (26)
the clutch line loop is the little box thing next to the frame rail right ??
also : i forgot to mention this a 96 with a ka24de
Old 09-22-2010, 05:47 PM   #4
S14DB
AFC #1
S14DB's Avatar
Yes, box between the hard line and the slave. has a loop that runs down the frame rail.
Old 09-22-2010, 05:54 PM   #5
S14Driftr91
Trader Rating: (26)
ok cool cool so ill try that and then get back to you guys. thanks for the help
Old 09-22-2010, 06:07 PM   #6
S14DB
AFC #1
S14DB's Avatar
Yeah hook the rubber line up to the hardline and throw the box and loop away.
Old 09-23-2010, 12:10 PM   #7
S14Driftr91
Trader Rating: (26)
thanks guys, i bled the box and loop and sure enough there was nothing but air in there. now my clutch is back to normal
Old 09-26-2010, 11:14 PM   #8
240sohc
240sohc's Avatar
240sohc is an unknown quantity at this point
i too also bled the damper box and slave cylinder but the clutch pedal was soft, so i then tried the removal of the damper box, and put in a new stainless steel line to the hard line and now the clutch pedal is firm and smooth. i guess that damper box really isnt needed.
240sohc is offline   Reply With Quote
Old 09-27-2010, 08:56 PM   #9
itwillboost
itwillboost's Avatar
itwillboost is an unknown quantity at this point
The damper box is a spare bleeder it's not needed.
itwillboost is offline   Reply With Quote
Old 09-30-2010, 10:55 PM   #10
younghatchowner
younghatchowner is an unknown quantity at this point
take off the stupid box loop shit its call the dampener box....take that off..connect the hard line str8 to the softline and bleed the slave..your clutch with be the same or harder...99.9% of any s chassis car you see at a car meet dont have that crap on there car
younghatchowner is offline   Reply With Quote
Old 10-01-2010, 12:01 AM   #11
brizanden
brizanden's Avatar
^lol so just cause most dont have it you have to get rid of at as a principle?
