Old 10-20-2010, 10:45 AM   #1
nismonowotnik
nismonowotnik's Avatar
Trader Rating: (-1)
nismonowotnik is an unknown quantity at this point
Feedback Score: -1 reviews
sileighty,s14,cobalt for sale!!
hey ppl i had a few things that came up and i need to sell some cars a.s.a.p.
1990 Nissan 240sx (sileighty) se
1995 Nissan 240sx
2005 Chevy Colbalt
Phone # :330-447-3487(call or txt for faster response)
Name :Patrick or Erin
1990 Nissan 240sx se (sileighty) 129,095 miles 5speed
I have had this car for about 3yrs now was my drift project. Car had the pig nose flip up front end also had stock suspension,4 lug,sohc,auto, with a stock body. Then I did a bunch of work to the car over the years it has tons of new parts I put on, I changed the front to a silvia and had the body work done and a ford denium blue metalic paint job done to it by solo customs. Car has been completely over hauled from the ground up new frame front to back car. I recenty had an accindent out in Chicago this summer and banged up the front end needs body work done to the hood an passenger side fender also broke drivers and passenger side headlight only could save the drivers side conner light, but drivers fender is perfect and front bummer needs work. Lookin to start a new build either a s13 coupe or a s14.looking to get about $4,900 if possible no trades on this car, make me an offer no low balling. If car doesn't sell in a month price may go down, also taking offers on parts on the car to test the waters on a possible part out.
UNDER THE BONNET
new fresh rebuilt from bottom up dohc gold valve cover
eagle rods,arp head studs,celvet rod bearings,an new valve seals and full gasket kit
Noalogy hott wires from a gsr motor
new NGK irritium plugs
stock header
stock cat
custom made cat back boso exhast
Felsons enginering short ram intake
egr block off plates and no butterfly valves in intake manifold
new 300zx fuel filter
new oem injectors
new nismo oil and coolant caps
new nismo motor and trans mounts
trust coolant cap
coolant overflow aluminum reservior
greedy oil filter adapter plate
new stock radiator and hoses
new summit raceing cooling fan
DRIVE TRAIN
5 speed converison with all oem hardware and lines, new flywheel bolts
new zoom stage 1 clucth kit
300zx VLSD with new s14 output shafts
new clutch slave cylinder
BRAINS
stock ecu
ROLLERS
s14 se painted gold "16" rims and new ssr replacas black with a polished lip +38 offset
tires that i run are bridgestones,goodyear,toyo,yokohama sizes from 205/45/16 - 225/55/16
new eibach 50mm wheel spacers for the rear and 10 mm front spacers
STOPPERS
Ichiba 5 lug hubs conversion front and rear (for you 4 lug haters)
z32 aluminum calipers
new z32 rotors and nissan pads and parking brake shoes
300zx e-brake canles and stock lines
STIFF STUFF
new EMS (Apexi N1) adjustable coilovers
new Energy suspension bushing kit
Nismo power brace was new looking but got cheaped up from being so low
new Gun metal front and rear strut bar braces
OUTSIDE
S13 oem silvia conversion triple beam headlights,Race on usa front oem lip, new VIS m-speed side skirts and rear bumper,
new origin 50 mm rear over fenders, oem tails with stock center and kouki chrome smoked on it both sets of lights had center garnish sparyed black,180sx origin wagon wing,s15 silvia badges and 180sx quater glass stickers to cover up the 240sx, and bunch of stickers on glass
INSIDE
gray s14 seats, momo 4 point harness with pads, nismo white(butt plug)shift knob, black leather red stitched shift boot
mint dash wit digi cluster with the hud, custom vent gauge wit auto meter 2 1/2in air fuel meter,sun pro 1inch oil pressure, volts, temp gauges
all black door pannels and red leather glove box, there are no rear seats or rear carpet or any pannals in the back, i needed space for rims and tires for track days
1995 Nissan 240sx 169,600 auto
I had this car for about a 1yr, was gonna start another project. Car needed sum work when i first got it since it was sitting in a lot for a yr or so. Car need a tune up we replaced the sparkplugs with some ngk irritiums plugs and new wires, new gas filter, new valve cover gasket, new front main seal, new power strearing lines, new brakes pads all around resurrfaced front rotors, new rear cailpers an cross drilled slotted rotors, new heater core replaced old plastic intake wit a cold air one, got rid of stock manifold and put a megan racing header on it and painted the valve cover gold. Replaced the trunk cause it was rusting up pretty bad where the spoiler was an it was half falling off,so we got a deck lid and removed the spoiler an welded up the holes and started the body work to it, also have a new spoiler to put on the car if u want it.it has 15in XXR 513 all flat black with the thin red stripe around the lip also has stock steel rims both sets of wheels have good tires on them and has a spare donutt in the back and extra tires.Car needs some body work to the rockers and driver side rear quarter pannel do to rust, frame is good no rust underneath of the car, also the car hasn't been in any accidents.Inside the car is clean passenger side inner door handle is broke also around the cd player. has cd player and blown speakers in front and rears about to go. Looking to get about $2,500 for the car with extra wheels.also can do trades for this car will take another clean s13 240sx coupe or hatch with some mods, but would like a coupe shell an some cash for it
2005 chevy colbalt 94,506 auto
We had this car now for a few yrs now as a daily driver lookin for sumthing different now.theres not much to say about a colbalt besides Its a dark blue four door, it has gray cloth seats and door trim,has cd player,manual window and mirrors,remote door locks,ac,heat, has a 2.2 eco tech motor and its a auto.we had to replace the muffler cause it got a hole in it. Has new tires on it and it just got a fresh oil change. Car is a great car gets u any where you need to go.need to get $5,000
We have a set of extra wheels for each of the 240's we are willing to sell seperate. Both sets are new and have used tires, we are asking $400 for each set.
16in SSR/work replicas black with polished lip 5 lug by 114 plus 38 offset
16in 5 lug SE wheels they are painted gold for $250
Also have a stock s13 rear bumper $50
nismonowotnik is offline   Reply With Quote
Old 10-22-2010, 01:00 AM   #2
h2v7
h2v7 is an unknown quantity at this point
whats up pat/
hope no hard feelings.
how are things? you back in ohio?
h2v7 is offline   Reply With Quote
Old 10-25-2010, 10:55 AM   #3
southernjake
southernjake is an unknown quantity at this point
straight up. you know how to rice a perfectly good sileighty.
Speed costs money... HOW FAST DO YOU WANNA GO?
93 Silvia SR
southernjake is offline   Reply With Quote
Old 10-26-2010, 12:28 AM   #4
nismonowotnik
Trader Rating: (-1)
h2v7 do i know u? what u mean rice up a perfectly good sileighty?yea deff back in ohio.pm me
Old 10-31-2010, 12:19 AM   #5
h2v7
