Old 11-17-2010, 07:46 PM   #1
stk240sx
stk240sx is an unknown quantity at this point
pipe ?? help please.
If you are facing the radiator the top left hose that goes into the motor and there is a pipe there that receives the hose. The pipe that catches the hose or where the hose goes in it has deteriorated. Can this pipe be replaced?
In the picture I circled the pipe with blue circle. The pipe is deteriorating and water is leaking on it. That picture is not a picture of my car.
Thanks for the help
stk240sx is offline   Reply With Quote
Old 11-17-2010, 07:58 PM   #2
kojiki88
kojiki88's Avatar
kojiki88 is an unknown quantity at this point
I'm not 100% sure but I believe it can be replaced.
kojiki88 is offline   Reply With Quote
Old 11-17-2010, 08:02 PM   #3
Sileighty_85
Sileighty_85's Avatar
IIRC its pressed in
You could, but youd have to remove all of the old pipe, find the same diameter pipe and press it in....
Or just replace that whole section of the IM with another
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 11-19-2010, 12:51 PM   #4
s14unimog
s14unimog's Avatar
Trader Rating: (22)
s14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond repute
Feedback Score: 22 reviews
Send a message via AIM to s14unimog
^ yeah its pressed in there, you'll never be able to do it correctly with the manifold on the car. I would just source another upper intake manifold and be done with it. Might as well service the IACV while you're there and check for other corrosion issues with all the lines/connections.
Fu*king ginger bread man stole my wallet...
SHIFTlock_slide to side
d3m3rs0n: if i have a baby im naming it Brandons Fault Emerson
s14unimog is offline   Reply With Quote
Old 11-20-2010, 06:05 PM   #5
stk240sx
can someone recommend a intake manifold? thanks
Old 11-20-2010, 07:26 PM   #6
Sileighty_85
well not much to choose from its either they stock KA IM or this one
Xcessive KA24DE Intake Plenum
後輪駆動車1番
1986 SR86 - 200ish
Old 11-20-2010, 08:00 PM   #7
s13 @ fullboost
s13 @ fullboost's Avatar
s13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfection
Send a message via AIM to s13 @ fullboost
you can buy one here http://zilvia.net/f/sale-items/35360...od-prices.html
s13 @ fullboost is offline   Reply With Quote
Old 11-22-2010, 04:04 PM   #8
stk240sx
I noticed that the aftermarket manifold and the pipe that is for the cooling system is only a straight pipe. The original manifold pipe also has a little pipe for the hose that goes to the block. why is the aftermarket only have a straight pipe? Is the the small pipe not necessary? thanks.
