Old 08-29-2003, 09:08 AM   #1
brianglawson
brianglawson's Avatar
brianglawson is an unknown quantity at this point
Send a message via ICQ to brianglawson Send a message via AIM to brianglawson Send a message via Yahoo to brianglawson
really stupid question but can someone explain a few boost questions
ok i see all the boost controlers out there and stuff can someone explain these and turbo timers such as like say i wanted to run 7 psi on the street and 14psi when i run it is it possible make the boost controller run in that much of a difference
also can someone completely explain a turbo timer to me
i know these are newbie questions which i am new to turbo's but please if you are gonna bash and flame me just dont respond i just want to have the knowledge of this. even a link to a site that explains it would be great
brianglawson is offline   Reply With Quote
Old 08-29-2003, 10:17 AM   #2
West
OMNOMNOMNOM
West's Avatar
West has disabled reputation
Send a message via AIM to West
Hmm, to much to explain.
Excellent Tech on EBC's
http://splparts.com/doc/tech/EBC.htm
Turbo Timers just keep your car running for a desired time after you turn the ignitoin off and remove your key. This helps cool the turbo after you drive hard and shut the motor off. It keeps the oil circulating enough so your turbo wont get heat soaked and cause it to fail over time.
West - Zilvia.net - Toyobaru.net - NapkinSketch.com
West is offline   Reply With Quote
Old 08-29-2003, 11:17 AM   #3
uiuc240
uiuc240's Avatar
uiuc240 is an unknown quantity at this point
Send a message via AIM to uiuc240
Originally posted by WeST
Turbo Timers just keep your car running for a desired time after you turn the ignition off and remove your key.
...and they are completely unnecessary on a water-cooled turbo. Unless you have an aftermarket turbo without a water-cooled center section, this is a waste of $100.
Eric
2002 Mazda Protege5
1989 S13 w/SR20DET (sold)
uiuc240 is offline   Reply With Quote
Old 08-29-2003, 11:25 AM   #4
brianglawson
thanks for the info man im just new to this i appreciate the info
Old 08-29-2003, 11:27 AM   #5
brianglawson
on that site say for a greddy profec b that you set the duty cycle and gain now what does this mean i could set where it would start as far as say 6-7psi to 13-14psi??
Old 08-30-2003, 10:30 PM   #6
Jeff240sx
I hate you too...
Jeff240sx's Avatar
A boost controller will hold in the neighborhood of 30psi easily, seeing as it is a simple valve that bleeds "Y" psi of air, fooling the wastegate/actuator into thinking its making "X" psi, even the turbo is running on "X + Y" psi. On EBCs, there are almost always a HI and LO setting, or A and B (depending on brand), and with a push of a button you can go from daily driving boost (6psi) to your racing boost (14psi).
-Jeff
Whatup?
