Old 12-14-2010, 09:38 AM   #1
tx3rdjamesb
tx3rdjamesb is an unknown quantity at this point
92 nissan 240sx ka24de injector problem
I NEED HELP. I am at wits end.( ).My 92 nissan 240sx drove great. Then for reasons unknown my #1 injector died. I made arrangements to take it to a shop but when i tried starting it to take it there it refused to start. I have replaced the fuel filter, fuel pump, new plugs, wires, rotor, cap, distributor with built in camshaft possitioning sencor, upper wiring harness, and a few relays. I checked all fuses. and yet it still wont start. everything else works like it should, but the injectors wont spray. I have plenty of fuel pressure, spark, and power to injectors. Why wont they open up and spray.
tx3rdjamesb is offline   Reply With Quote
Old 12-14-2010, 09:47 AM   #2
sliddinsil8o
sliddinsil8o's Avatar
sliddinsil8o will become famous soon enoughsliddinsil8o will become famous soon enoughsliddinsil8o will become famous soon enoughsliddinsil8o will become famous soon enough
Send a message via AIM to sliddinsil8o Send a message via Yahoo to sliddinsil8o
bad injector. replace bad injector. start car. hope that helps
****SIGNATURE EXCEEDS FORUM LIMITS....PLEASE READ THE RULES****
sliddinsil8o is offline   Reply With Quote
Old 12-14-2010, 02:48 PM   #3
driftn_silvia
driftn_silvia's Avatar
driftn_silvia is a name known to alldriftn_silvia is a name known to alldriftn_silvia is a name known to alldriftn_silvia is a name known to alldriftn_silvia is a name known to alldriftn_silvia is a name known to alldriftn_silvia is a name known to alldriftn_silvia is a name known to alldriftn_silvia is a name known to alldriftn_silvia is a name known to alldriftn_silvia is a name known to all
injector is probably clogged, but it should still turn over. It would just idle really rough, would sound like a WRX idle.
Do you hear the fuel pump turning on?
driftn_silvia is offline   Reply With Quote
Old 12-14-2010, 02:59 PM   #4
doomviillain
doomviillain's Avatar
doomviillain is an unknown quantity at this point
Send a message via Yahoo to doomviillain
have u tried changing the fuel rail + injectors? Go to ur local junkyard
You are seventeen.
Your argument is invalid.
doomviillain is offline   Reply With Quote
Old 12-15-2010, 07:35 AM   #5
Rogueanonymous
Rogueanonymous's Avatar
Rogueanonymous is an unknown quantity at this point
Send a message via AIM to Rogueanonymous
rogues help
Check starter? Spark plugs?Fuel pump?Short?
Rogueanonymous is offline   Reply With Quote
