Old 12-17-2010, 08:54 AM   #1
dued
dued's Avatar
dued is not welcome here anymoredued is not welcome here anymoredued is not welcome here anymoredued is not welcome here anymoredued is not welcome here anymoredued is not welcome here anymoredued is not welcome here anymoredued is not welcome here anymoredued is not welcome here anymoredued is not welcome here anymoredued is not welcome here anymore
Smile Clunk in Rear - Have solid Subframe Bushings
Hi Guys, I'm trying to research a new clunking noise I have coming from the rear of my s14. I have stance solid subframe bushings, so no problems there. I recently swapped my diff for a j30 however. I've been reading alot and it seems like there is play in the driveshaft from other people's descriptions. My question is, considering that the j30 was most likely an abs car, and my s14 is non abs, could there be a length problem in the driveshaft causing enough room for play and causing the clunk? Is there any way I could make a spacer to fix the problem? I haven't found a solution for this & I'd like to get it solved for everyone else out there.
dued is offline   Reply With Quote
