Old 01-02-2011, 02:55 PM   #1
roadster6909
roadster6909 is an unknown quantity at this point
Bolt & head ticking problem
So after tapping the thread i made a new bolt, washers, and put it in, its still leaking.
Unscrewed it, had some shavings inside the bolt from tapping, took it out put back in and still leaking..
I don't understand why it is still leaking from the lower line from the turbo by the block??
EDIT: Not leaking anymore, used rubber washers, but they will most likely melt... Still ticks though.
Im going to take the turbo in to sound performance, chicago, and they are going to do this for me, after that im going to work on the noise but i need suggestions. as to what you guys think it is
Around 2 mins(After it sits by the shifter, second try, it fires up and idles fine.)
Car running bogging cold start head noise. Most likely due to loss of oil pressure.
http://s1107.photobucket.com/albums/...t=M4H05098.mp4
roadster6909 is offline   Reply With Quote
Old 01-02-2011, 09:39 PM   #2
nissansrdub
nissansrdub's Avatar
nissansrdub is an unknown quantity at this point
dude i feel your pain. i got the same bolt leaking and a ticking sound coming from my head too! if i dont work tomorrow im gonna bleed the lifters and check that for my noise. and for the bolt i might just put some honda bond or some type of silicone. its not a daily driver so i dont know. lol good luck
nissansrdub is offline   Reply With Quote
Old 01-02-2011, 10:04 PM   #3
Sileighty_85
Sileighty_85's Avatar
Helicoil or weld on a -AN fitting with Steel braided lines.
Bleed lifters
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 01-02-2011, 11:51 PM   #4
roadster6909
Is their an alternative for the bolt? Tapping kits cost like 75$..It screws in but you cant tighten it all the way, just turns and turns..Idk if loctite would work due to oil pressure... suggestions?
Old 01-03-2011, 05:09 AM   #5
Sileighty_85
Really Guy?
That shit is stripped meaning the threads are fucked, these are your only two options for a real reliable fix
Loctight wont do shit
後輪駆動車1番
1986 SR86 - 200ish
Old 01-03-2011, 08:49 AM   #6
HPKMotorsports3
HPKMotorsports3's Avatar
HPKMotorsports3 is an unknown quantity at this point
sileighty just told you what to do... and yes you can tap and die it as well
Originally Posted by shiftdrift View Post
you running on hopes and dreams?
HPKMotorsports3 is offline   Reply With Quote
Old 01-03-2011, 02:31 PM   #7
roadster6909
My pops works with metal and i don't have the keys to my garage.. he's going to make me a bit longer of a bolt.
And ill put some loctite on that thing; i'll post results.
Old 01-06-2011, 03:39 PM   #8
roadster6909
Up loaded pics/ vids/ information, tapped it and put new bolt but still leaking from somewhere
Old 01-06-2011, 07:07 PM   #9
nissansrdub
that sounds way louder than what im talking about. get some brake cleaner and spray off that whole side of the block. once its clean use a flash light and look to see. is your turbo oil line hooked up? i hope your block isnt cracked. thats a lot of oil. good luck bro
Old 01-07-2011, 03:20 PM   #10
roadster6909
Cleaned it up, found its still coming from turbo line, unscrewed bolt, tried blowing through it and barely could.. Looked inside the bolt, and all i see are a bunch of metal shavings inside of it, from the tapping.. Would this cause it to leak? Would i be able to use this bolt if i took the shavings out? Kind of looks like it worn a bit, as shown in pics.
Edit: I cleaned out the shavings, put it back in, and it is still freakin leaking, theirs no way! Why?!
Old 01-07-2011, 05:11 PM   #11
Sileighty_85
Weld on -AN fitting
Problem solved
後輪駆動車1番
1986 SR86 - 200ish
Old 01-07-2011, 05:36 PM   #12
roadster6909
What do you mean by -an fitting?
Sorry, but i don't know what an "-AN fitting is"
Google shows various of pictures, im curious as to what exactly you mean..
Old 01-07-2011, 06:24 PM   #13
nissansrdub
does the bolt tighten up?
Old 01-07-2011, 06:29 PM   #14
roadster6909
Yessir, I retapped the thread, got a new, bigger bolt, tapped the oil line, bolt didnt fit so i drilled a bit so the bolt can turn and tighten without messing up the thread in the block. Tightens up nice and good, have copper "break hose bolt washers" On both sides. Still leaks from the washers it seems like because it's wet.
Old 01-07-2011, 07:00 PM   #15
Sileighty_85
Something like this
Summit Racing SUM-220063 - Summit Racing® Weld-In Bungs - Overview - SummitRacing.com
you weld it in place of where the bolt goes,
They are easier and seal way better than banjo bolts
後輪駆動車1番
1986 SR86 - 200ish
Old 01-07-2011, 07:05 PM   #16
roadster6909
Is their anything i can buy that would be at a local store/ shop?.. Anything else that would work?
These copper brake washers are doing a poor job sealing.
Old 01-08-2011, 10:07 AM   #17
roadster6909
Used rubber washers and that solved the leaking problem, but cant use them because they will melt..now time to find out what the head noise is D:<
Suggestions?
