Old 04-24-2008, 11:38 AM   #1
dori_sil8t
dori_sil8t's Avatar
dori_sil8t is making a name for him/her selfdori_sil8t is making a name for him/her self
SR sr20det spark plugs
ok i have searched and found these numbers ngk numbers
bkr6egp 7092 stock number
7090 i found on here 13b sentra
bkr7es11's
im just wondering what everyone is running?
unionautoclub.com
dori_sil8t is offline   Reply With Quote
Old 04-24-2008, 11:40 AM   #2
fbiphil
fbiphil's Avatar
fbiphil has much to be proud offbiphil has much to be proud offbiphil has much to be proud offbiphil has much to be proud offbiphil has much to be proud offbiphil has much to be proud offbiphil has much to be proud offbiphil has much to be proud offbiphil has much to be proud offbiphil has much to be proud offbiphil has much to be proud of
Just replaced mine yesterday- NGK BKR6E1X
I had a misfire under load/ boost, and once I replaced the plugs it's running better than ever!
I hear that you can go to a 7E1X if you're running more than 14-ish psi of boost- search around for confirmation on that.
These are Iridium plugs, so be ready to pay $6-8 per plug- but it's worth it, as the Iridiums are supposed to hold up to high heat better than standard copper plugs. Good luck!
fbiphil is offline   Reply With Quote
Old 04-24-2008, 11:46 AM   #3
SoguRacing
SoguRacing's Avatar
SoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfection
Send a message via AIM to SoguRacing
I'm running NGK heat range 7. i believe the next step up is 6? correct me if i'm wrong.
Pre Tune Checkup! Compression,LeakDown,Vacuum Test $80. Cams Install: $180
SoguRacing is offline   Reply With Quote
Old 04-24-2008, 12:12 PM   #4
NIZzS13
NIZzS13 is an unknown quantity at this point
Spark plugs
Yeah 6 is next but I heard if your car is like a daily driver and not heavily modded that the 6 plugs will foul out or get messed up and thows iridiums ain't cheap.
NIZzS13 is offline   Reply With Quote
Old 04-24-2008, 12:17 PM   #5
flip3d
flip3d's Avatar
flip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond repute
Send a message via AIM to flip3d
I thought stock was 6? 1 step colder for every 100hp.
Personally, I use BKR6E-11. Copper core V-power. They're only like $2 a plug so you can change them at every oil change.
flip3d is offline   Reply With Quote
Old 04-24-2008, 12:56 PM   #6
SHIFT_*grind*
SHIFT_*grind*'s Avatar
SHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfection
Higher # = colder plug. Factory heat range is 6. I'm using 7s. People debate on whether 6s or 7s are better for a mostly stock motor with a few bolt-ons (exhaust/FMIC/small boost increase), but a 7 definitely won't hurt anything.
If you change your spark plugs often, you may as well save your money and just buy copper plugs rather than iridium. They actually produce a slightly better spark than iridiums or platinums, they just need to be changed more often.
My seller review thread
SHIFT_*grind* is offline   Reply With Quote
Old 04-24-2008, 01:58 PM   #7
dori_sil8t
dori_sil8t's Avatar
thanks guys. im gonna run the 7's see what happens. nothn major is done to the sr just exh manifold. fmic. exhuast, the norm.
unionautoclub.com
Old 01-07-2011, 07:46 AM   #8
ka24det92
ka24det92 is an unknown quantity at this point
Dose anyone run bkr6esp I can get them at work for cheap I just want to know can I run the on a Sr with bolt on and about 14lbs
ka24det92 is offline   Reply With Quote
