Old 09-11-2003, 08:35 PM   #1
turboex
turboex is an unknown quantity at this point
Weight reduction????
Ok so far I have taken the whole interrior out to paint it black, ut im trying to decide what to leave out. Ok first i plan to keep the carpet out and use bed liner in a thin coat for a black effect. Then all seat belts were removed, mine are electric so here heavy as hell. Ill be using a harness anyways.next all the rear truck and seat stuff is going to be gone. any other ideas?
1992 240sx SE
s13 silvia frontend conversion
SR20DET, custom top mount turbo manifold, Precision SC61 turbo, blitz bov, HKS intercooler, Tial 38mm wastegate, tenzo-r shu-4's, ton of other shit. with clean new paint!
turboex is offline   Reply With Quote
Old 09-11-2003, 08:48 PM   #2
240Dave
240Dave's Avatar
240Dave is an unknown quantity at this point
Even a thin layer of truck bed liner is going to be as heavy or heavier than the carpet that was in there. Only, now your car will be ugly and loud on the inside.
The rest of the stuff (and it was posted a couple weeks ago, try a search) only weighs a very little bit.
I say just take the spare tire out and call it a day.
Just FYI incase you care, harnesses aren't safe in a rollover incase you have a roll bar because your body may not be able to move and your head will be crushed. But the chance of a rollover is pretty minimal on the street, so its up to you, just understand the risk.
I've heard people mention breakaway harnesses or soemthing but I'd never feel safe useing anything like that.
good luck with whatever you decide to do...
240Dave is offline   Reply With Quote
Old 09-11-2003, 08:54 PM   #3
turboex
good point on the belts, im gonna hit up the junk eard tomorrow and see if they have a 240 with manual belts in it, as i hate the electric ones
1992 240sx SE
Old 09-11-2003, 09:37 PM   #4
Bill Roberts
Bill Roberts is an unknown quantity at this point
I posted a primer on how to deal with electric belts that fail. I might be of use.
Do you have any pics of the way the motor connects and all? I am curious, I have not seen the motor for them. Rear spiler is heavy, get rid of it (s-13) and try to attain a 50/50 balance. Go top a garbage dump and weigh your car. I am running damn close to 50 /50.
1484 front. 1458 rear with me in the car and 1/2 tank of fuel.
Bill Roberts is offline   Reply With Quote
Old 09-12-2003, 10:47 AM   #5
FRpilot
FRpilot's Avatar
i dont htink you'll find manual seatbelts for s13 unless you live in canada or japan. you can, however, use s14 manual seatbelts. i forgot whats involved, but i think you need the belts and you might need to cut your interior panels unless you source the canadian ones. search for more info.
FRpilot is offline   Reply With Quote
Old 09-12-2003, 01:15 PM   #6
Uniac
Uniac is an unknown quantity at this point
Send a message via MSN to Uniac
i gots an extra s13hb, with manual belts, it's brown interior though, and i have seen an american spec s13 with manual belts (junk yard), but the cluster could just have been changed. don't know how easy they are to take out
Uniac is offline   Reply With Quote
Old 09-12-2003, 02:16 PM   #7
hurleyboi514
hurleyboi514 is a well-known jackass
Send a message via AIM to hurleyboi514
that half tank of gas in the back certainly helps that 50/50 set up. im off on a friday nite (AMAZINGLY!) and have nothing to do until late, so i think ill probably take some stuff out and see what i can do about weight loss. and btw, you need to get the he11 out of florida man, have you seen that hurricane coming your way??!!
HighTach Motorsports
hurleyboi514 is offline   Reply With Quote
