Old 09-14-2003, 08:09 PM   #1
andrave
andrave's Avatar
andrave is an unknown quantity at this point
Send a message via AIM to andrave
quick camber questions (yes I searched)
Ok I have Tein S tech lowering springs and my car has some pretty negative camber in the back. So I'm going to take it in to get it aligned. My question is, will I have excessive front camber problems too?
Should I
1) Get some front camber correction bolts and take it in to get aligned?
or 2) take it in to get aligned and if they say its got too much camber in the front, THEN get the front camber bolts. they come in +/- 1 or +/- 2 and I don't know which ones I would need. It didn't lower it much so I can't imagine I'd need more than 1 degree of adjustment, if any.
what do you guys think?
andrave is offline   Reply With Quote
Old 09-14-2003, 10:16 PM   #2
Fastback180
Fastback180's Avatar
Fastback180 is an unknown quantity at this point
Send a message via AIM to Fastback180
Rember what we discussed?
Fastback180 is offline   Reply With Quote
Old 09-14-2003, 10:43 PM   #3
andrave
andrave's Avatar
yes, but even though its only 25 bucks, if I don't need camber adjustment up front, its 25 bucks wasted.
so whats the deal? should I spent 25 bucks I might not need and get it aligned, or should I go and get it aligned, accepting the fact that I might be sacrificing some tire life?
Old 09-15-2003, 07:18 AM   #4
Dousan_PG
Dousan_PG's Avatar
christ how many times do we have to cover this
CAMBER DOES NOT KILL TIRES
TOE kills tires
TOE
not camber
Toe
t-o-e toe!!!!!!
i ran -3.5 degrees camber normal wear at streets for months and months..track..now that's a different story!
but on the street, i know LOTS LOTS of people w/ -2.5 on streeet tires last VERY LONG TIME!!
Aaron
Pink GodziRa
Old 09-15-2003, 01:42 PM   #5
Replicant_S14
Replicant_S14's Avatar
Replicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of light
Yup, it's fine.
andrave-
Do you know what camber you're at right now? (front and rear).
I have some camber correcting bushings (Whiteline) for the rear waiting to go on. My car isn't very low either but I need them to get the rear camber slightly more upright than what I have the front set at. It's a handling preference tho, the tire wear is not an issue at all.
Rules of Boozing #10: Do not make eye contact with the bartender if you do not want a drink.
Replicant_S14 is offline   Reply With Quote
