Old 02-08-2011, 09:21 AM   #1
FloridaKush
FloridaKush is an unknown quantity at this point
sr22det LONGBLOCK MAZWORX/HEADGAMES
UP for sale is my sr22det long block.
I have receipts for all work done to the motor, and i haver logged exact mileage on the motor (under 7k miles right now) selling, because im going with a different Motor... PITA..
Ok,
Bottom End - 90mm Mazworx bottom end, thats 90mm 9:1 CP pistons, Darton Sleeved, 19mm rod bearing ect ect Turbo tuff Rods, 1/2" Head Studs ect ect (will send invoice from mazworx)
Head - Hemi ported head with solid 280 Tomei cams, full supertech valve train.. ect ect.. (all of this is also on the invoice)
I can also include a 67mm turbo if the price is right?
Look - as the MAZWORX invoice will show, there is about 16-17k in the longblock build. I am asking $9000 obo... somewhat flexible.
Last time i had a 90mm motor i drove to meet the person, I would like to do the same as I dont feel safe 'shipping' something like this (at all)
email [email protected] with any serious requests ... I will email you the invoices and we can take it from there.
FloridaKush is offline
Old 02-08-2011, 03:37 PM   #2
FloridaKush
oh and i forgot to mention... there are wayyy to many posts on this forum!! lolol
Old 02-10-2011, 07:14 AM   #3
FloridaKush
some of whats there.
Street/Strip Short Block***
CPP SC7329 CP Pistons, 90.0mm 9.0:1 CR, SR20DET 525.00 525.00
CAL PC Calico Coatings, Piston 4 45.00 180.00
MAN 14408-4 Manley Turbo Tuff Rods for SR20DET 725.00 725.00
CAL 1T2964 Calico Coated ACL Thrust Bearing Set, Nissan
SR20DET
11.83 11.83
CAL 4B2976H Calico Coated ACL H-Series Rod Bearing Set, 19mm
Wide, Nissan SR20DET
69.34 69.34
CAL 5M2975H Calico Coated ACL H-Series Main Bearing Set, Nissan
SR20DET, w/ 5 Oiling Holes
136.93 136.93
ARP 202-5402 ARP Main Studs for SR20 110.00 110.00
NIS 13500-50F00 Oil Pump, S13 SR20 240.00 240.00
DAR 300-035-DF Nissan SR20 Dry Sleeve, Double Flat 2 90.00 180.00
DAR 300-035-SF Nissan SR20 Dry Sleeve, Single Flat 2 90.00 180.00
MAZ SR12HSK Mazworx 1/2" Head Stud Kit w/ Dowels 225.00 225.00
PWR SR90 Power Enterprise SR20DET Headgasket, 90mm Bore 250.00 250.00
MAZ SRHGM Machine Headgasket for 1/2" Head Studs 35.00 35.00
MAZ SRCRRP Clean and R/R Oil Ports, Block 150.00 150.00
MAZ SROG Oil Groove Machining, SR20 90.00 90.00
MAZ SRSI Sleeve Install 280.00 280.00
MAZ SRHSB SR 1/2" Stud Machining, Block 210.00 210.00
MAZ SRRBM 19mm Rod Bearing Machining 105.00 105.00
MAZ SRLB Resize Line Bore 200.00 200.00
Item Description Qty Cost Total
MAZ SRCPBC Check, Polish, Balance Crank 175.00 175.00
MAZ SRBL Balance Recipricating Assy. 150.00 150.00
MAZ SRBORET Bore & Hone w/ Torque Plate 320.00 320.00
MAZ SRRS Resurface Block & Oil Pump 100.00 100.00
MAZ SRASS Assemble Motor, Provide Spec Sheet 560.00 560.00
***Street/Stip Built Head***
SUP SPR-H1020... Supertech Dual Valve Springs, SR20, 116 lbs on seat 16 9.77 156.32
SUP RET-NSR20... Supertech Titanium Retainers, SR20 16 11.57 185.12
SUP SEAT-H/N240 Supertech Inner Spring Locator, 7mm Valve, SR20 (ea) 8 2.57 20.56
SUP SEAT-SR20/6 Supertech Inner Spring Locator, 6mm Valve, SR20 (ea) 8 2.57 20.56
SUP GDE-NSR6-... Supertech Nissan 6mm Exh guide, Mang. Bronze (for
replacement of 7mm guide)
8 5.79 46.32
SUP GDE-NSR6-I Supertech Valve Guide Intake Nissan SR20DET/RB26
6 mm stem Manganese Bronze
8 5.79 46.32
SUP VS-TS6E Supertech Exhaust Valve Stem Seal, SR20DET w/ 6mm
Stem
8 1.00 8.00
SUP VS-N6I Supertech Intake Valve Stem Seal, SR20 (ea) 8 1.00 8.00
SUP NIVN-1007 Supertech Intake Valve, +1mm, SR20 8 15.56 124.48
SUP NEVI-1007 Supertech Inconel Exhaust Valve, +1mm, 6mm Stem,
SR20
8 23.10 184.80
NIS 13218-53J00 Rocker Guide 8 4.42 35.36
NIS 13257-53J03 Rocker 8 29.57 236.56
Page 2
TOM 163003 Tomei Solid Pivot 240.00 240.00
TOM 1435280125 Tomei Solid Type Camshaft, 280, 12.5 Intake, S13 260.00 260.00
TOM 1436280125 Tomei Solid Type Camshaft, 280, 12.5, Exhaust, S13 260.00 260.00
MAZ SRCRRP Clean and R/R Oil Ports, Head 150.00 150.00
MAZ SRCNCS Mazworx CNC Street Port w/ 90mm Combustion
Chambers
850.00 850.00
MAZ PPS2 Stage 2 Port and Polish
Gasket Match, Bowl Work, Blend and Polish
800.00 800.00
MAZ SRVG R/R Valve Guides 16 15.00 240.00
MAZ SRHSH SR 1/2" Stud Machining, Head 105.00 105.00
MAZ SRVJDET Competition Valve Job 350.00 350.00
MAZ SRRSH Resurface Head 75.00 75.00
MAZ SRRG Grind Rockers for Dual Guide Conversion 70.00 70.00
MAZ SRHASS Assemble/Shim (Solid Pivots), Provide Spec Sheet 350.00 350.00
***Assemble Long Block***
TOM 13024R310 Tomei Adjustable Cam Gear 2 180.00 360.00
NIS A302H-53JO... Timing Chain, SR20 92.48 92.48
NIS 00926-51600 Crank Key 0.97 0.97
NIS 13021-53J00 Sprocket, Crank, SR20 13.63 13.63
NIS 13070-2J203 Timing Chain Tensionor, SR20 68.88 68.88
NIS 13079-2J200 Tensioner Gasket 5.97 5.97
NIS 13085-1N500 Timing Chain Guide, Fixed, SR20 17.10 17.10
NIS 13091-2J202 Timing Chain Guide, Adjustable, SR20 73.72 73.72
NIS 13094-53J01 Bolt, Adjustable Tensioner 2.67 2.67
ATI 918582 ATI Super Dampner, SR20 425.00 425.00
NIS 12279-AD205 Rear Main Seal, SR20 17.58 17.58
NIS 15050-65F01 Oil Pickup, SR20 45.00 45.00
NIS 15053-1E400 Oil Pickup Gasket, SR20 5.00 5.00
MAZ SRUOP Machine Upper Oil Pan for ARP Clearance 45.00 45.00
Labor Assemble Long Block, Degree Cams 3 70.00 210.00
***Needed Cores in Good Condition***
Block, Mains, Girdle
Upper/Lower Oil Pans
Head, Caps, Bolts, Oil Tubes
Rear Main Housing
Crank
Old 02-10-2011, 08:15 AM   #4
TheClutchKicker
TheClutchKicker's Avatar
TheClutchKicker is an unknown quantity at this point
Pictures??
TheClutchKicker is offline
