Old 06-18-2006, 10:20 PM   #1
timlush
timlush's Avatar
timlush is a splendid one to beholdtimlush is a splendid one to beholdtimlush is a splendid one to beholdtimlush is a splendid one to beholdtimlush is a splendid one to beholdtimlush is a splendid one to beholdtimlush is a splendid one to beholdtimlush is a splendid one to beholdtimlush is a splendid one to beholdtimlush is a splendid one to beholdtimlush is a splendid one to behold
Send a message via AIM to timlush
bottom line on 300zx e-brakes?
is this how most people do it? i was told that doing it this way can cause the e-brake to be engaged when the car is jacked up. can anyone confirm or deny this?
timlush is offline   Reply With Quote
Old 06-18-2006, 10:57 PM   #2
infinitexsound
infinitexsound's Avatar
infinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond repute
dont do it that.. way.... it doesnt work well and the cable just slips when u pull the handle..... best way is to reroute the cables the long way and use a cable clamp...those dubro collars are junk..
S14 TrackSlut coming to a raceway near you...
510 TimeAttack on its way...
infinitexsound is offline   Reply With Quote
Old 06-18-2006, 11:59 PM   #3
95zilvia
95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light
dang i need to do something like that. my ebrake cables still dont work.
95zilvia is offline   Reply With Quote
Old 06-19-2006, 01:52 AM   #4
timlush
timlush's Avatar
well, what i had in mind as far as cable clamps are not what's in that picture. i searched for a pic of them to post to see if they would be better but i couldn't find a pic. the clamps i was wanting to use are kinda the same concept of some battery terminals where i would put both cables in and tighten 2 bolts on either side of the cables. those the ones you are talking about? (sorry if that's a bad description)
Old 06-19-2006, 02:04 AM   #5
j_ren180
j_ren180 is an unknown quantity at this point
Does anyone have the e-brake cable kit for S13s? How effective is that?
j_ren180 is offline   Reply With Quote
Old 06-19-2006, 02:46 AM   #6
WilloW
WilloW's Avatar
WilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfection
Send a message via AIM to WilloW Send a message via Yahoo to WilloW
I'm using R33 cables on my S14 for the Z32 ebrakes.
WilloW is offline   Reply With Quote
Old 06-19-2006, 03:17 AM   #7
DaN_S13
DaN_S13 is an unknown quantity at this point
Does anyone know if the e-brake cables from a UK spec s13 would work with the z32 brakes since they also have the disc/drum brake setup.
DaN_S13 is offline   Reply With Quote
Old 06-19-2006, 09:58 AM   #8
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
Feedback Score: 48 reviews
S13 - Re-route Z32 cables.
S14 - R33 cables.
Done
Old 06-19-2006, 11:00 AM   #9
Dousan_PG
Dousan_PG's Avatar
i use YANACK ebrake lines on my s14
i used stock z32 lines on my s13
both have/had the rear z brakes
never had a problem
iirc flybert uses the z32 ones too on a s13
Aaron
Pink GodziRa
Old 06-19-2006, 11:06 AM   #10
Realchaos1
Realchaos1 is a well-known jackass
Send a message via MSN to Realchaos1
yeah I would be worried that the cable would slip. The bolts could come loose slowly and your screwed.
wtf... they came with drum brakes?? ...
Realchaos1 is offline   Reply With Quote
Old 06-19-2006, 11:06 AM   #11
drift freaq
R.I.P. Aya, always love
drift freaq's Avatar
Trader Rating: (215)
Feedback Score: 215 reviews
R33 e brake cables will work on the s13 as well.
New Video
Buy my mounts!
Old 06-19-2006, 12:00 PM   #12
statik
statik's Avatar
statik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond repute
Send a message via AIM to statik Send a message via MSN to statik
hes referring to the e-brake portion, its seperate from the caliper itself
97 240sx esaarr | Current Status: SOLD
statik is offline   Reply With Quote
Old 06-19-2006, 12:52 PM   #13
rancid240
Trader Rating: (72)
rancid240 will become famous soon enoughrancid240 will become famous soon enoughrancid240 will become famous soon enough
Feedback Score: 72 reviews
S14 - R33 cables.
Done
Is there a consensus yet on wether or not 2+0 lines are shorter?
rancid240 is offline   Reply With Quote
Old 06-19-2006, 01:04 PM   #14
240trainee
240trainee's Avatar
240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection
Send a message via AIM to 240trainee
I dunno, the lines I have will not fit an S13, they are definatly too short. I think they are off of a 2+2, though I am not sure. it seriously bums me out that they don't fit though....
Team Pterodactyl
SHARK ATTACK!!!
LookoutDrift
240trainee is offline   Reply With Quote
Old 06-19-2006, 03:09 PM   #15
rancid240
Trader Rating: (72)
Mine fit, from a 2+2. Are they too long or too short?
Old 06-19-2006, 04:38 PM   #16
240trainee
240trainee's Avatar
Mine are like 8-12" too short.
Team Pterodactyl
SHARK ATTACK!!!
LookoutDrift
Old 06-19-2006, 07:12 PM   #17
AWDtoyota
AWDtoyota is just really niceAWDtoyota is just really niceAWDtoyota is just really niceAWDtoyota is just really niceAWDtoyota is just really niceAWDtoyota is just really niceAWDtoyota is just really niceAWDtoyota is just really niceAWDtoyota is just really nice
Ok I think I have the answer for the S13 guys.
This was done on a 91 240SX hatchback.
I tried both the regular Z32 cables, and the 2+2 cables.
First attempt was the standard Z32 cables, these cable DO reach. They just have to be rerouted through the subframe, some costom brackets need to be made, and the handle needs to be loosened almost all the way. This setup worked fine, and the handle felt very close to the feel of the original setup.
But I am a perfectionist and I had to try all the options untill I am satified. The 2+2 cable is next. This cable is longer than the standard z32 cable, its about the same length as the stock 240SX cable. I am still fine tuning this setup so I'm not fully complete. But this setup requires alot of adjustment at the handle. You have to take up alot, and I mean alot, of slack. I routed this cable the same as the standard z32, and made custom brackets for it as well.
Right now I have the 2+2 cables on the car, after the further fine tuning, I will make my decision on which cable to run permantely, but right now I like the regular z32 cable better.
Here are some comparsion pics, and rerouting pics:
Top to bottom: 240SX cable/ Regular 300ZX cable/ 300ZX 2+2 cable
Left to right:240SX cable/ Regular 300ZX cable/ 300ZX 2+2 cable
regular 300ZX cable top, and 300ZX 2+2 cable bottom
240SX cable top, and 300ZX 2+2 cable on bottom
Rerouting:
These are of the regular 300ZX cable....2+2 pics coming soon....
E-brake cable passed through the oval shaped hole in the subframe (how it comes on the Z32's)
Cable passed over the exhaust, and bracket used to hold it away from the driveshaft.
The next pics are of the routing, and the custom bracket I made.
Any question, let me know, I will do my best to answer them. If you need more pics, I will try to get those for you also. I'm still working on the 2+2 setup, so when I finish I will let you guys know how that goes compared to the standard Z32.
Hope this helps......
AWDtoyota is offline   Reply With Quote
Old 06-19-2006, 07:58 PM   #18
240trainee
240trainee's Avatar
That is exactly what I was looking for, gonna give it a shot on the project car in a couple weeks, thanks very much. I just must be dumb then and not looked at hou best to route everything.
Team Pterodactyl
SHARK ATTACK!!!
LookoutDrift
Old 06-20-2006, 09:43 AM   #19
rancid240
Trader Rating: (72)
I did the same for my 2+2 lines. But I used the bracket that you used to keep it from the exhaust, in the location that you made a custom bracket. I did adjust the handle as tight as it would go, and the brakes lock up very nicely. I only have to pull up 4 -5 clicks and it locks up all the way. BTW my 2+2 lines look more like your regular z32 lines (concerning the bracket up top near where it mounts to the handle).
Old 06-20-2006, 10:11 AM   #20
flytwa78
flytwa78's Avatar
flytwa78 will become famous soon enoughflytwa78 will become famous soon enoughflytwa78 will become famous soon enoughflytwa78 will become famous soon enough
Doesn't SPL Parts sell pre-made lines.
flytwa78 is offline   Reply With Quote
Old 06-20-2006, 12:18 PM   #21
eds13
eds13's Avatar
eds13 is close to perfectioneds13 is close to perfectioneds13 is close to perfectioneds13 is close to perfectioneds13 is close to perfectioneds13 is close to perfectioneds13 is close to perfectioneds13 is close to perfectioneds13 is close to perfectioneds13 is close to perfectioneds13 is close to perfection
Send a message via AIM to eds13
i think i have z32 lines. i got them off of a car s13 that had z brakes in the rear.
i just need to adjust them and get them working right
eds13 is offline   Reply With Quote
Old 06-20-2006, 12:38 PM   #22
SoSideways
SoSideways's Avatar
I didn't find anything just now, so I would lean towards "NO".
Old 06-20-2006, 02:16 PM   #23
XxJaPxOxNeEs23xX
XxJaPxOxNeEs23xX's Avatar
XxJaPxOxNeEs23xX is making a name for him/her selfXxJaPxOxNeEs23xX is making a name for him/her self
Send a message via AIM to XxJaPxOxNeEs23xX
this is what i have done for my s14. i didnt make it my dad did because i dont know how to weld, but this is just a suggestion.
rest are on here
http://share.shutterfly.com/action/w...id=8DbMWzRy1fQ
XxJaPxOxNeEs23xX is offline   Reply With Quote
Old 06-20-2006, 08:05 PM   #24
timlush
timlush's Avatar
i have an s14 and $300 for r33 cables is not an option. i'm gonna try the cable clamps
Old 06-20-2006, 08:10 PM   #25
WilloW
WilloW's Avatar
Wow, $300? Who gave you that quote? I bought mine from Performance Nissan for $110 and some change. Oh yeah, I got great service from them too, they got good people working there.
Old 06-20-2006, 09:13 PM   #26
projectRDM
projectRDM's Avatar
Damn, you're buying four pair for one car? Why you need three extra pair?
Old 06-21-2006, 08:41 AM   #27
SoSideways
SoSideways's Avatar
Originally Posted by XxJaPxOxNeEs23xX
[OT]
What brand RLCA is that? Looks hot as hell. And if you bought it, where did you get it from? And how much?
Thanks.
[/OT]
Old 06-21-2006, 02:11 PM   #28
XxJaPxOxNeEs23xX
rlca means rear lower control arm right? if it is its an ikeya formula, got it when i was in japan. it was 700 somthing. i got it 2 years ago, so might be cheaper? its adjustable, so the angle of camber can be adjusted any way you want while extending the tire out a little further.
SeVen
Old 06-21-2006, 02:27 PM   #29
240trainee
240trainee's Avatar
Like $834 from spl. probably would be easier to get, though i dunno.
Team Pterodactyl
SHARK ATTACK!!!
LookoutDrift
Old 06-21-2006, 04:44 PM   #30
SoSideways
SoSideways's Avatar
Well, here's my thread on the Nismo LCA from FA.
http://forums.freshalloy.com/showthr...=nismo+control
Now, back to our regularly scheduled programs...
