My KA-T build 91 & E85 Daily driver S14
Thanks for viewing my thread :mrgreen:
This will be my first time tackling the KA-T project so any and all advice is welcome. I've had stock KA's, SR20's, and RB25s so this should be a fun time. It will more than likely be a slow build/process, however I will upload the thread with pictures whenever I do get a chance to work on the motor. Picked up my s14 rolling shell (with complete motor) non running about a month and a half ago (10/15/2015). Picked up up a long block today for $100 and brought it home. Owner stated it had a water pump failure which caused it to blow the HG; I didn't mind as I will be rebuilding the block. My goals for this is going to be 400whp on E85 as my daily driver. Hope to have a dual tune for 91 & E85 as 91 is the highest here, besides the E85, however it's not always the easiest to get. Luckily for me I have 2 E85 stations both within 5 miles from me so I shouldn't have a problem, it's when I travel in the car it may become an issue. Parts I plan on using for the build: - Clevite main & rod bearings - Wiseco 9.0:1 90mm pistons - Eagle connecting Rods - Felpro engine gasket set - OSK Timing chain kit - OEM Nissan oil pump rebuild w/ rebuilt regulator - OEM Nissan water pump - Felpro KA24DE engine gasket kit - 97' KA 5speed Tranny - XTD RB flywheel - ACT RB HD street clutch kit - JGS Rubber motor mounts - JGS Rubber tranny mount - Aluminum radiator One thing I haven't decided yet is the turbo I'll be using for this build. I plan on going the stand alone route as far as engine management goes, however if I end up not being able to fit it in the budget I'll more than likely go Nistune/Nismotronic. HAPPY BUILDING! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ***NOTE*** Make sure you ALWAYS label your baggies so you know which nuts/bolts go to what. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Scrapping away the silicone gasket with a blade. ![]() [/quote] Last edited by 2.5T_/<ouki; 12-18-2015 at 07:12 PM.. |
