![]() So I bought a friends friends s14 brought it home yesterday everything was running smooth after we got the tires to not rub in the front
Anywho today I head out to school and on my way back it starts acting odd it would act like it just shut off the key and then i started it back up and it was fine then once more it stalled out just this time i couldn't get it to start back up the negative battery terminal connector was bad went and replaced that. Drove fine shut it off started it back up was perfect then last but not least I was on my way to work and the car shut off right in the intersection couldn't get it to start tried jump starting it then tried bump starting it nothing. Symptons are now: All dash lights will stay on even when key is out of ignition Car's reverse lights work even when key is out of ignition ECU relay buzzing at random times when I try starting it then it stays buzzing Things I've tried: I've 95% of the fuses under the dash and every fuse under the hood I've checked the grounds even added a new one where I thought it could use one since the old one was going bad. Swapped out relays from under hood to the ecu still nothing I'm quite stumped on this right now basically everything is electronically stock besides the MINES TUNE ECU... Help me out I miss it already Oh also this car was running perfectly fine for the time that he had it and then yesterday the ground terminal connector was bad so I replaced that and this is all that's its doing now Complete car specs PULSAR GTI-R T28 turbo with the S14 compressor housing swap adjustable wastegate running 12 psi megan dump pipe megan downpipe test pipe combo blitz 85mm exhaust 255 walbro fuel pump front mount greddy bov fidanza aluminum flywheel fidanza 4.3 clutch with 6 pad sprung disc mmr tranny mount 4.4 gears with vlsd aluminum alt and water pump pulley big aluminum rad with dual 12 in fans MINES TUNE ecu NISMO fuel pressure regulator |
Tags |
no start, s14, sr20 |
