![]() Join Date: Oct 2003
![]() I've got rod knock on #3, and the cars been parked for a few weeks now. I've already decided to just get a standard set of ACL bearings, and replace all 4 while I'm at it. Right now I'm hoping that the crank doesn't have any scarring, and that at most it will only need a polish. I'm pulling the motor out next weekend, and I'll know for sure then. Does anyone have a suggestion on a technique to polish the crank without pulling the crank out, or taking it to a machine shop? My reasoning behind that is that I haven't ordered any main bearings, and I'd rather not have to mess with them. I've heard of the 2000 grit emery paper wrapped around the journal, and using a shoe string to keep even pressure, but that's mainly on classic domestic motors with looser tolerances. I've also heard of scuffing the crank with a scotch brite pad. Would either of those be good choices, or would I be better off slapping the new bearings on as-is if I don't see any scarring?
If you had rod knock I assure you that the crank will be out of spec. The damage will be obvious when you take apart the motor, but you can have the crank re-ground and saved but you will need to speak with the machinist on the sizes of bearings you will be needing depending on the damage(.010/.020/.040). Main journals will also need to be machined and bearings ordered accordingly, so with that said order rod/main bearings and consider a OIL PUMP!
Andrew p.s. you should order bearings after you have crank ground. |
Yeah, I figured if I saw any damage I'd have to pull the crank. If that's the case I'll talk to the machinist, and order rod/main bearings with the specs he suggests. As soon as I heard rod knock the car was shut down, and I'm hoping it'll be ok... we'll see once it's apart. The car had been sitting for a month or previous, and the rod knock appeared first time I got on the throttle at about 3.5k which I hoped would minimize damage. I don't have the money for a new OEM pump, but I do have an oil pressure gauge to keep an eye on.
#4 | |
![]() Join Date: Nov 2009
![]() Feedback Score: 8 reviews
This is true. You should have searched before ordering anything |
A few of the local guys here have had luck with just throwing in a standard set after light knocking, and that's the main reason I've ordered a set to have on hand when I get the motor out. My main concern is whether or not I should try to hand polish the crank or just throw the bearings in if I don't see scarring. Right now it sounds as if no one goes about rod bearings without first going to the machine shop.
#6 | |
My one buddy has put 115k on the S13 since he put the bearing in back in 03' which is the longest I know of. He only replaced the one bearing making noise though with an OEM bearing. The other guys have different makes an models, but most of them have a few years on the rod bearing replacements. I'm not against taking my crank to a machine shop, but I'm hoping to be able to have the motor back in the car Sunday. Otherwise I won't have another free weekend to put the car together until mid-late summer. Generally this car is only driven maybe 50 miles a week with an occasional autocross thrown in for good measure.
