Old 10-09-2003, 10:01 AM   #1
twitchy
twitchy's Avatar
twitchy is an unknown quantity at this point
Keyless entry doorlock help PLEASE!
Hey all
Im installing a new alarm on my car with keyless entry and Ive been at it all night. Its going fairly well although all Im stuck with to do is the door locks. Im wondering if anyone has ever done these before and can help. I have the factory wires exposed and I have the kick panels and everything off. I have the special relay needed to control the door lock system on my 93 240SX and I need to know if anyone knows what the hookups are to make...
1) Wheres the factory door lock relay, or is there one
any information helps please and thanks!
JP
PS If anyone has a radar perimiter sensor on their car and has any tips for its installation that would be great too (ie where to put i, etc)
Who the hell needs a sig anyhow
twitchy is offline   Reply With Quote
Old 10-09-2003, 11:22 AM   #2
mbmbmb23
Zilvia Contributor
mbmbmb23's Avatar
mbmbmb23 is on the path to ruinmbmbmb23 is on the path to ruin
I believe the door lock timer relay plugs in right near the ECU.
-m
400x200
mbmbmb23 is offline   Reply With Quote
Old 10-10-2003, 07:50 AM   #3
SilviaDET
SilviaDET is an unknown quantity at this point
Send a message via AIM to SilviaDET
perimiter sensor
Ummm, take the perimiter sensor, go to the store you bought it at, return it for a glass break sensor, install that instead.
The reason I say this is most perimeter sensors that we install at my shop (CarToys) have issues. for example, when the weather changes the zone changes, when you park under sodium lighting (large parking lots) the zones change, if you eat a big mexican dinner the zones change... you get my point.
If you have a convertable, or a jeep then it is one of the few options for security that you have.
If you have a hardtop then put a glass break sensor on it (detects sounds of glass breaking, of metal on glass(slimjim) or even sometimes even if people try to flex the window it will set it off. then make sure that you roll up your windows when you leave your car.
I've just seen too many people comming back every other week to get the zones adjusted on the perimeter sensor.
on the door locks, ill check the alarm wiring info for the 93 when I get into work and post up an answer for ya.
SilviaDET is offline   Reply With Quote
Old 10-10-2003, 08:04 AM   #4
twitchy
twitchy's Avatar
THANKS!
Old 10-10-2003, 10:45 AM   #5
mbmbmb23
Zilvia Contributor
mbmbmb23's Avatar
http://www.zilvia.net/f/attachment.php?s=&postid=327653
Door lock timer is pictured here....
http://www.zilvia.net/f/attachment.php?s=&postid=327654
...and plugs into the connection M61
-m
400x200
