Old 10-23-2013, 04:59 PM   #1
NickS14
NickS14 is an unknown quantity at this point
OEM clutch with KA-T setup
Recently going 5spd, in the process, motor I bought came with a Nissan OEM clutch with ~1k mi, according to the owner. I have a pretty basic setup, Garret T3T4 turbo, with sr20 injectors running at 8psi... Just curious if and for how long clutch will hold up...
NickS14 is offline   Reply With Quote
Old 10-23-2013, 09:03 PM   #2
UnknownGuy
UnknownGuy's Avatar
UnknownGuy is an unknown quantity at this point
Run it. There isn't any real telling how long its gonna last, but I can tell you eventually when it does go out your gonna want to go with a more aggresive clutch and pressure plate setup.
UnknownGuy is offline   Reply With Quote
Old 10-23-2013, 09:27 PM   #3
Kallixtos
Kallixtos's Avatar
Trader Rating: (61)
Kallixtos is just really niceKallixtos is just really niceKallixtos is just really niceKallixtos is just really niceKallixtos is just really niceKallixtos is just really niceKallixtos is just really niceKallixtos is just really nice
Feedback Score: 61 reviews
I think if your planning on making more power later on, why not just upgrade to something a bit better. Save yourself the trouble of having to wrestle the trans on the ground (if you don't have a lift or work at a shop).
Kallixtos is offline   Reply With Quote
Old 10-23-2013, 09:30 PM   #4
NickS14
Funds are a little tight. Not planning on making much more power any time real soon. It's not like I'm putting out huge hp numbers just didn't kno how many ftlb the stock nissan clutches were rated at...
Old 10-23-2013, 09:35 PM   #5
codyace
codyace's Avatar
Trader Rating: (58)
Feedback Score: 58 reviews
Don't push it very hard at all, it'll just make issues worse.
Old 10-23-2013, 10:09 PM   #6
NickS14
There's no issues at all right now... Just curious if it's even worth dropping in... There's no point if it's going to slip every time I boost. Will it hold at all?
Old 10-23-2013, 10:15 PM   #7
feito
feito's Avatar
feito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymore
i tried a ka-t t25 9psi with a stock vatozone clutch once and it'd slip a lot
feito is offline   Reply With Quote
Old 10-23-2013, 10:21 PM   #8
Kallixtos
Kallixtos's Avatar
Trader Rating: (61)
It probably wont last as long as you want it to. You have to remember its made for a 150hp 155 ft/lb motor. Do it right and you wont have to worry about it slipping.
Old 10-24-2013, 07:05 AM   #9
codyace
codyace's Avatar
Trader Rating: (58)
Ah, I misread it.
I mean the 370cc injectors will keep you to 225ish hp, but the KA torque will push you past the clutch limit for sure
Old 10-24-2013, 07:11 AM   #10
stevenrapids
stevenrapids's Avatar
stevenrapids has a reputation beyond reputestevenrapids has a reputation beyond reputestevenrapids has a reputation beyond reputestevenrapids has a reputation beyond reputestevenrapids has a reputation beyond reputestevenrapids has a reputation beyond reputestevenrapids has a reputation beyond reputestevenrapids has a reputation beyond reputestevenrapids has a reputation beyond reputestevenrapids has a reputation beyond reputestevenrapids has a reputation beyond repute
oem clutch would probably hold for awhile, but save yourself the hassle and spend the $300 to do a clutch while you are doing the 5 speed. It will give you peace of mind too.
instagram@stevie_fingers
350z for sale
stevenrapids is offline   Reply With Quote
Old 11-16-2014, 04:07 PM   #11
J90lude
J90lude's Avatar
J90lude J90lude J90lude J90lude J90lude J90lude J90lude J90lude J90lude J90lude J90lude
An upgraded clutch is worth it. Just use what you have now. Just save up for one.
"Drive it like you running from the cops"
J90lude is offline   Reply With Quote
Old 11-28-2014, 12:11 AM   #12
kruked
Trader Rating: (37)
kruked is an unknown quantity at this point
Feedback Score: 37 reviews
No, the clutch will not last. I'm speaking from experience.
One used clutch, one brand new clutch, (both stock ka clutches) then went w/ an rb flywheel and z32 clutch setup.
I blew both ka clutches in less than 3 months. They both slipped under 8lbs of boost, always.
Don't waste your time.
S13 coupe, KA-t
kruked is offline   Reply With Quote
Old 12-10-2014, 12:20 PM   #13
Chaluska
QFT!
I went with the RB/Z33 combo as well. holds up to 12psi on my Bullseye S259 turbo.
Old 12-10-2014, 02:05 PM   #14
Bushido
Bushido's Avatar
I have a barely used Nismo Coppermix clutch for sale!! Perfect for basic KA-T
Old 12-10-2014, 02:51 PM   #15
bmaddock
bmaddock's Avatar
bmaddock is an unknown quantity at this point
One of the last parts of my "doing it wrong" years, I tried saving money and running RB25 flywheel and RB25 Exedy OEM clutch on my KA-T. It holds fine, even through a drift event at T3/T4 12psi but I would recommend using an upgraded RB25 clutch.
Somehow my clutch pedal felt softer with the OEM RB25 clutch than the OEM KA clutch that was once there. I was running a new Master, slave, freshly bled fluid and stainless steel line on both setups. I believe the culprit is the OEM RB25 pressure plate.
Edit: this is an old thread that's been bumped.. well hopefully this helps someone else that searches for this thread
bmaddock is offline   Reply With Quote
Old 12-10-2014, 03:19 PM   #16
mewantkouki
Trader Rating: (36)
mewantkouki will become famous soon enoughmewantkouki will become famous soon enoughmewantkouki will become famous soon enough
Feedback Score: 36 reviews
Stock clutch ate shit under 8psi with a t28. No hard driving whatsoever. Couldn't hold anything over 4k rpm in 1st or 2nd gear. It only got worse.
mewantkouki is offline   Reply With Quote
