Old 05-25-2011, 05:25 PM   #1
imnotniko
imnotniko is an unknown quantity at this point
wheel hitting coilover. help needed
i have an s13 with tein he coilovers and i just got enkei rpf1's 17x9.5 +18 all around with 235/40/17 tires. i installed the wheels up front and they are hitting the coilover. im assuming i need to run a spacer to clear the coilover but i don't know what size. any help? i have a picture.
imnotniko is offline   Reply With Quote
Old 05-25-2011, 05:27 PM   #2
dt-p88
dt-p88 is an unknown quantity at this point
Try a 5mm?
dt-p88 is offline   Reply With Quote
Old 05-25-2011, 05:33 PM   #3
CleanAndLegit
CleanAndLegit's Avatar
Trader Rating: (55)
Feedback Score: 55 reviews
more like a 9-11mm cause i have enkie gtco1s 18x9+18 and am like 3mm away from coil
Old 05-25-2011, 05:38 PM   #4
theboy
theboy is an unknown quantity at this point
10mm spacer and you should be fine, probably need to roll and maybe pull the fenders
theboy is offline   Reply With Quote
Old 05-25-2011, 05:41 PM   #5
imnotniko
yeah once i get the wheels on the car thats the first thing i am going to do. i think i might purchase a 15mm spacer for the front just incase. should i do the same for the rear?
Old 05-25-2011, 08:20 PM   #6
chuy
chuy has a spectacular aura aboutchuy has a spectacular aura aboutchuy has a spectacular aura aboutchuy has a spectacular aura aboutchuy has a spectacular aura aboutchuy has a spectacular aura about
+1 for the 10 mm spacer, I run the same suspension and wheel size. Except my offset is 15
Slide Happy
chuy is offline   Reply With Quote
Old 05-25-2011, 08:49 PM   #7
naw_speed
naw_speed's Avatar
naw_speed is an unknown quantity at this point
you should try to slot the top or bottom hole in the strut to spindle bracket first. that will allow the wheel to tilt just enough so that it will clear the coil springs. and you can still run up to 1.5 degs of camber depending on your coilovers. some coilovers come pre sloted for this reason. it,s cheaper that spacers and you don,t have to worry about spacing the rear to match....18x9.5 +20 and i got no problems.
))-> sil front on.. time for rocket bunny kit<-((
naw_speed is offline   Reply With Quote
Old 05-25-2011, 09:02 PM   #8
ladyzx
ladyzx's Avatar
ladyzx is an unknown quantity at this point
10 mm should fix it
ladyzx is offline   Reply With Quote
Old 05-26-2011, 09:32 PM   #9
Robb
Robb is an unknown quantity at this point
Are ou 4 or 5 lug? I have an unused spare pair of H&R 20mm spacers if you need something.
Robb is offline   Reply With Quote
Old 05-26-2011, 10:55 PM   #10
imnotniko
5 lug i think im going to try a 10mm
Old 05-26-2011, 11:27 PM   #11
sr20sean
sr20sean's Avatar
Trader Rating: (25)
sr20sean is an unknown quantity at this point
Feedback Score: 25 reviews
Send a message via AIM to sr20sean
you should know they dont make good offset rpf1's in 4 lug!
TLDR
Cliff notes: Florida
sr20sean is offline   Reply With Quote
Old 05-27-2011, 12:27 PM   #12
Robb
I would normally research first, but I was on my phone. Figured that I would be generous and just post the offer to him.
Old 05-27-2011, 02:56 PM   #13
imnotniko
im good thanks man. im going to purchase h&r track spacers
