Old 03-31-2011, 09:34 PM   #1
Matej
Trader Rating: (39)
Feedback Score: 39 reviews
Stiffer throttle body spring?
Does such a thing exist?
In my case it would be for a KA24DE. The spring is weak/worn, and combined with a slight kink in my throttle cable due to it being rerouted, under vacuum it usually does not shut the throttle body all the way, causing the motor to idle at around 1900 RPM. I thought I had a vacuum problem somewhere, until I found out the sole cause is the throttle body not shutting completely.
I will replace the spring or possibly the entire throttle body. However, I would really like to keep my throttle cable tucked as it, so I am curious if there is such a thing as a stiffer throttle spring. Highly doubt an aftermarket one exits, but I was thinking there may be one that is interchangeable from a different model of car.
Cheers.
Old 04-01-2011, 07:31 AM   #2
92dagrey
92dagrey is an unknown quantity at this point
not really sure but you could try to find a similar stiffer spring at a hardware store. just a suggestion. also does the tb stick? or just not close? could need cleaned
92dagrey is offline   Reply With Quote
Old 04-01-2011, 03:43 PM   #3
soreballz
soreballz's Avatar
Trader Rating: (22)
Feedback Score: 22 reviews
^ you've never looked at the TB spring on a 240, have you?
-Kyle
Old 04-01-2011, 03:46 PM   #4
herbieS13
herbieS13's Avatar
herbieS13 is an unknown quantity at this point
Send a message via AIM to herbieS13
if the way u have ure cable routed is causing it to kink u need to unroute it lol
herbieS13 is offline   Reply With Quote
Old 04-01-2011, 03:48 PM   #5
pandaroo
pandaroo's Avatar
pandaroo is an unknown quantity at this point
you could always make a bracket and add a separate spring ghetto style lol. but since your tucking it anyway i don't think you'd be into it.
89 2tone coupe
2jzgte swap in progress
pandaroo is offline   Reply With Quote
Old 04-01-2011, 06:01 PM   #6
92dagrey
never had a problem with one..so no not really.
Old 04-02-2011, 01:01 PM   #7
1337
1337's Avatar
1337 is close to perfection1337 is close to perfection1337 is close to perfection1337 is close to perfection1337 is close to perfection1337 is close to perfection1337 is close to perfection1337 is close to perfection1337 is close to perfection1337 is close to perfection1337 is close to perfection
Send a message via AIM to 1337
cut the spring, and re bend it.
1337 is offline   Reply With Quote
Old 04-14-2011, 11:20 AM   #8
Matej
Trader Rating: (39)
Looked at this yesterday. There are actually two separate springs, and only one of mine was hooked up. The other was not attached to the pulley correctly.
Now the pedal feels normal and the throttle body works well again.
Old 04-14-2011, 09:07 PM   #9
chiboy002
post pics of engine bay glory!
PLS!
street dancer.
GLEAM
