Old 03-02-2011, 01:22 PM   #1
motoxris
motoxris is an unknown quantity at this point
s13-s14 knuckle difference
I was trying to search this but it wasn't working. Is the taper for the control arm mount on the knuckles the only difference? Other than that the s13/s14 knuckle look the same.
motoxris is offline   Reply With Quote
Old 03-02-2011, 01:38 PM   #2
Pantaloons
Pantaloons's Avatar
Pantaloons is an unknown quantity at this point
the spindle size is also different
Facebook
Twitter
Pantaloons is offline   Reply With Quote
Old 03-02-2011, 04:06 PM   #3
motoxris
anything else?
Old 03-02-2011, 04:11 PM   #4
theboy
theboy is an unknown quantity at this point
the bolt holes that go to the struts/coilovers are bigger in the s14 and the spindles on s14s are larger
theboy is offline   Reply With Quote
Old 03-04-2011, 12:36 AM   #5
rei_k's
rei_k's is an unknown quantity at this point
Bolts are only bigger on 5 lug
rei_k's is offline   Reply With Quote
Old 03-04-2011, 09:25 AM   #6
Mobne
Mobne is an unknown quantity at this point
You can mount them right on the s13 chassis. Its probably not optimal sulution but it works.
200sx s13 - 705whp -youtube.com/mobne -Streetperformance.se
Mobne is offline   Reply With Quote
Old 03-04-2011, 10:37 AM   #7
abunai the drifter
abunai the drifter's Avatar
abunai the drifter is making his/her stupidity well-knownabunai the drifter is making his/her stupidity well-knownabunai the drifter is making his/her stupidity well-knownabunai the drifter is making his/her stupidity well-known
Send a message via Yahoo to abunai the drifter
need to replace the ball joint for the spindel to sit right or uses14 flca
screw you guys im going drifting
abunai the drifter is offline   Reply With Quote
Old 03-05-2011, 03:04 PM   #8
motoxris
Yeah. Using s14 lca is nice because there something like a half inch longer. But I just need to know the differences between the two.
Old 03-05-2011, 10:04 PM   #9
MrMcgarrett
MrMcgarrett's Avatar
Trader Rating: (313)
MrMcgarrett is close to perfectionMrMcgarrett is close to perfectionMrMcgarrett is close to perfectionMrMcgarrett is close to perfectionMrMcgarrett is close to perfectionMrMcgarrett is close to perfectionMrMcgarrett is close to perfectionMrMcgarrett is close to perfectionMrMcgarrett is close to perfectionMrMcgarrett is close to perfectionMrMcgarrett is close to perfection
Feedback Score: 313 reviews
Send a message via AIM to MrMcgarrett
4 lug and 5 lug S14 spindles are the same.
Originally Posted by Mobne View Post
You can mount them right on the s13 chassis. It's probably not optimal solution but it works.
They do fit but you wouldn't want to risk your car or your life on it.
To the OP.
The differences are the shock mounting holes (S13-12mm vs. S14-14mm)
The ball joint taper(S14 is bigger I believe)
The hub mount is thicker and shorter on the S14 spindles.
MrMcgarrett is offline   Reply With Quote
Old 03-05-2011, 10:47 PM   #10
motoxris
So everything else is pretty much the same including geometry?
Old 03-05-2011, 11:19 PM   #11
MrMcgarrett
I'm not sure since I've never taken any measurements of them.
Here is a side by side pic of them(S14 on the left):
Old 03-05-2011, 11:33 PM   #12
motoxris
Yeah they look close
Old 03-30-2011, 08:31 PM   #13
1337
1337's Avatar
1337 is close to perfection1337 is close to perfection1337 is close to perfection1337 is close to perfection1337 is close to perfection1337 is close to perfection1337 is close to perfection1337 is close to perfection1337 is close to perfection1337 is close to perfection1337 is close to perfection
Send a message via AIM to 1337
s13 knuckle has smaller spindle bolt/nut sizes and uses a different ball joint.
1337 is offline   Reply With Quote
Old 04-19-2011, 08:19 PM   #14
SiDwAyZ240
SiDwAyZ240 is an unknown quantity at this point
Does anybody know about the rear? I was wondering if the upright bushings are the same for S13 and S14.
SiDwAyZ240 is offline   Reply With Quote
Old 04-19-2011, 08:20 PM   #15
phobs
Trader Rating: (60)
phobs is an unknown quantity at this point
Feedback Score: 60 reviews
Rear is the same except for the strut mounting point.
phobs is offline   Reply With Quote
Old 04-21-2011, 03:44 AM   #16
[email protected]
Advertiser
Mogli@9KRacing.com's Avatar
Trader Rating: (87)
Mogli@9KRacing.com is an unknown quantity at this point
Feedback Score: 87 reviews
Send a message via AIM to Mogli@9KRacing.com
/end thread.
LIKE 9K Racing On Facebook for discount and product updates.
http://www.facebook.com/9KRacing
Contact 9K racing for any of your tuning or modifying needs.
Mogli@9KRacing.com is offline   Reply With Quote
