Old 10-10-2003, 01:54 PM   #1
The ROMAN
The ROMAN is a splendid one to beholdThe ROMAN is a splendid one to beholdThe ROMAN is a splendid one to beholdThe ROMAN is a splendid one to beholdThe ROMAN is a splendid one to beholdThe ROMAN is a splendid one to beholdThe ROMAN is a splendid one to beholdThe ROMAN is a splendid one to beholdThe ROMAN is a splendid one to beholdThe ROMAN is a splendid one to beholdThe ROMAN is a splendid one to behold
Aftermarket L.S.D.
Does anyone know if Aftermarket lsd's like Kaaz and cusco will fit into 240's that didn't come with it?
The ROMAN is offline   Reply With Quote
Old 10-10-2003, 02:04 PM   #2
nokeone
on strike three.
nokeone's Avatar
nokeone is making a name for him/her selfnokeone is making a name for him/her self
Send a message via AIM to nokeone Send a message via MSN to nokeone Send a message via Yahoo to nokeone
yes, kaaz (i will only speak of this cause it's what i have) is the center section only..you crack open your stock, no-vlsd, differential and replace all the interior pieces, gears, etc with what was provided to you by kaaz..
just simple remove and replace..that is all..
rather easy..just time consuming and lots of sweat from wrenching on 100+ ft/tq'd bolts..
panda; rockin your socks from the Bay to LA to SD, yay!
Pink GodziRa
nokeone is offline   Reply With Quote
Old 10-10-2003, 02:09 PM   #3
Var
Var's Avatar
Send a message via AIM to Var
They dont provide ring and pinion do they? How much for the whole kit?
Old 10-10-2003, 02:13 PM   #4
nokeone
on strike three.
nokeone's Avatar
true, u use your stock ring gear...
i think they run about $1000 retail..
Pink GodziRa
Old 10-10-2003, 08:55 PM   #5
s14slide
s14slide's Avatar
s14slide is an unknown quantity at this point
Send a message via AIM to s14slide
I've got a KAAZ 2-way for sale if your interested. Brand new. Email me if your interested.
= My day
s14slide is offline   Reply With Quote
Old 10-11-2003, 02:39 PM   #6
SpeedMonkeyInc
SpeedMonkeyInc's Avatar
SpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond repute
Did you need any specal tools? I really want to do this operation myself to save $$$ but am worried that I won't know what I am doing once I get in there. I can't afford to have my car down for more than a day.
Any advice?
SpeedMonkeyInc is offline   Reply With Quote
Old 10-11-2003, 03:33 PM   #7
kanekz
kanekz's Avatar
kanekz is an unknown quantity at this point
Is it for S13 or S14. used or new? PM me if you can with your email
kanekz is offline   Reply With Quote
Old 10-11-2003, 03:36 PM   #8
kanekz
kanekz's Avatar
Any advice?
Leave it to the pro's if you dont have any experience with this. If you take the pumpkin out yourself and take it to a shop...you save some money there. It'll usually run $150-200 for install. IMO, if you dont know what your doing, its not going to be worth the pains and troubles to learn ESPECIALLY if you cant afford the car to be down for more than a day!
Old 10-11-2003, 08:42 PM   #9
S14lover
S14lover's Avatar
S14lover is an unknown quantity at this point
don't you need new oupput shafts as well? cause you have an open diff and changing it to a LSD with both tires getting traction at the same time wouldn't you need 2 new output shafts. i believe they have to be the same ones to like 2 right side output shafts or something...dunno anyways why dont you do a parts search on carparts.com and find yourself a infinity J30 VLSD they bolt right on an S14 with now other mods.
She ****ing hates me ....TRUST!
S14lover is offline   Reply With Quote
Old 10-12-2003, 08:52 AM   #10
SpeedMonkeyInc
There are lsds made that don't need new output shafts. Kazz and Tomei both make such a unit.
Aside from that, a VLSD and a clutch or mechanical type are in diffrent performance leauges entirely. Upgrading to a clutch or mechanical diff is a serious performance modification, when installing a viscous is mearly an improvement over the open diff.
Old 10-12-2003, 03:10 PM   #11
RBS14
RBS14's Avatar
RBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura about
the internals of S13 and S14 diffs are the same.
RBS14 is offline   Reply With Quote
