Old 06-04-2011, 08:47 PM   #1
xnissan240sx
xnissan240sx is an unknown quantity at this point
RB25det Balancer pulley problem
So When I was going to take off my balancer pulley to change my oil pump, timing belt, and water pump I threaded in my 6mm bolts and when i started to turn the bolt in the center to pull it off one of my bolts stripped out all the threads in one hole. So now I am left with no way of getting this balancer pulley off. My question is can I use a 3 tooth gear puller to take the pulley off or do you "have" to use the balancer puller?
Thanks!
xnissan240sx is offline   Reply With Quote
Old 06-04-2011, 08:54 PM   #2
smoked240
smoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymore
Send a message via MSN to smoked240
I don't see why it wouldn't work. I removed mine with 2 pry bars equally spaced with the right amount of pressure and it slipped off.
smoked240 is offline   Reply With Quote
Old 06-04-2011, 09:00 PM   #3
xnissan240sx
okay because what I have is a large enough gear puller to go all the way to the last pulley.
Old 06-04-2011, 10:19 PM   #4
xnissan240sx
I just want to make sure that I don't wreck the balancer pulley in doing so.
