Old 11-19-2010, 01:29 AM   #1
Chue240sx
Chue240sx is making a name for him/her selfChue240sx is making a name for him/her self
Sold, please close mods!
Mods, please close thread. Car is sold.
Now for sale or trade for RX7 FD
This is my daily driver, located in bay area on weekdays and 95901 on weekends. SMOGGED and passed beautifully on 4/25/11. Only reason I'm selling is because I want an RX7 and need cash for the summer.
Price: $8,000 Firm, $6500 w/out wheels
1995 Nissan 240sx Base model, no sunroof
clean title
206,xxx miles
Manual 5-speed
Engine 9/10
All stock KA24DE except for K&N replacement air filter and z32 fuel filter
Compression 180psi all four cylinders
No check engine light
Recently replaced with genuine Nissan Knock sensor and Denso 02 sensor
Idles perfect at ~730rpm and drives perfect with ~28mph on fwy
A/C, Heater, and PW steering are all there and work great
Apex N1 full cat back 3 inch exhaust.
lifetime warranty autozone water pump
lifetime warranty kragen starter
Duralast gold battery
Interior 9/10
Black and Gray. All stock also except for front floor lights and a broadway rear view mirror
No crack on dash. Very clean dash and panels.
Poineer CD player with ipod connect, mp3, etc.
Power doors and windows. Everything works. The driverside door won't lock electronically but does so manually with the key and from inside the car. The window sometimes doesn't work unless you give it a little nudge on the arm rest and it then it works fine.
Comes with Nardi short hub and no brand quick release
Exterior 8/10
Version Select Type 1 Full Kit
Nissan Solid Red A54 Paint Job, primer, 4 base coat, 4 clear coat, then buffed, waxed, and polished
Front kouki conversion with oem hood, fenders, bumper retainer, headlights, corner lights, dmax clear signal lights, oem USDM Grill
Blue HID low beams
Rolled and pulled rear fenders
Rolled front fenders
Have stock trunk while holes filled
Have extra stock s14 rear bumper also painted same color as car
Shaved antenna
Wheel/Suspension/Brake
Works VS-XX: Fronts: 18x10+0 225/40/18 Sunny Tires; Rears: 18x11.5+19 265/35/18, rears will need to be replaced soon.
z32 26mm front brakes with stainless steel conversion lines
z32 rear brakes w/stainless steel conversion lines
Full working z32 e-brake setup with R33 e-brake cables
Cross and drilled rotors
Apex EVX N1 full coilover kit (awesome for DD and track)
Powertrix RUCAs, traction rod, toe rods, tension rods
Megan rear chasis bar
Cusco rear sway bar
Godspeed front sway bar
Cusco front tension bar
Custom/cusco front strut bar
Aluminum Subframe spacers
Extra Godspeed rear sway bar. Also still have stock front sway bar.
Bad: cosmetic stuff
small circle cracked in driverside headlight cover but everything functions perfectly. Will come with an extra light with clean clear glass cover.
small crack/chip in front bumper which needs to be repair
A crack in the front bumper lip but it was refiberglassed. Not straight though but isn't very noticeable.
Was in a fender bender but frame is straight, everything lines up perfectly and no airbags deployed.
3 wheels have curb rashes and all could use more love
Pictures: After buff and polish and wax pictures by chue240sx - Photobucket
***That is not a rip, just light reflection***
Chue240sx is offline
