![]() Join Date: Jul 2006
Trader Rating: (53)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 53 reviews
FS: NC: 240sx KA24DE Heads S13 & S14
FS: NC: 240sx KA24DE Heads S13 & S14 Concord, NC 28025 [email protected] __________________________________________________ _________________________________________________ S14 240sx KA24DE Head ///SOLD/// Pulled from a 96' running motor that was pulled for a motor swap and then parted out. Inside has been cleaned Also comes with valve cover (no bolts), cams, cam gears, idler gear/bolts Inside valve cover is very clean, cams are like new condition Around 120k miles ![]() ![]() __________________________________________________ _________________________________________________ S13 240sx KA24DE Head $135.00 Pulled from a 93' running motor that was pulled for burning 1qt of oil a month - will need new valve oil seals - I can do this for an aditional $65.00 (parts included) Also comes with valve cover (no bolts), front upper timing cover (no bolts) cams, cam gears, idler gear/bolts ///No Exhaust Cam/// Around 180k miles A little damage on the front 2 cam caps - but does not affect the performance at all (check pix) ![]() ![]() __________________________________________________ _________________________________________________ S13 240sx KA24DE Head $100.00 Pulled from a 91' running motor that needed new rings (low compression) Also comes with valve cover (no bolts), idler gear/bolts No front cover, lifter/shims or cams Has rust but will come clean with a hot tank Around 190k miles ![]() ![]() __________________________________________________ ________________________________________________ KA24DE Cams with gears S14 Intake - $20.00 (2) S13 Intake - $20.00 S13 Exhaust - ///SOLD/// ![]() ![]() __________________________________________________ ________________________________________________ All pix located here: http://s82.photobucket.com/albums/j274/jos...eads/?start=all Last edited by JDS Performance; 07-05-2011 at 09:30 PM.. |
