Old 07-11-2011, 04:33 PM   #1
Eky_drifter
Eky_drifter's Avatar
Eky_drifter is an unknown quantity at this point
Angry Steering problem help
so i take my 95 240sx to the allignment shop and after they finished was told i need steering rack bushings. so i get me some energy suspenstion polly bushing set. get it installed. the reason i needed them in the first place was that my car would jurk left or right when ever it wanted to while driving. drivable but a pain in the ass. so after i install them its much better! but after driving it for 2 days its worse then before! ??? so i looked at everything and found that just a few bolts were loose on the lower control arm and the tension rod. but would that cause it to feel like im driving with crazy tow in? just jurks me left or right how ever the damn thing feels fit!
what should i look out for?
parts i have!
PBM tension rods and toe rods.
SPL toe ends
PBM coilovers
steering rack moved forward
power brace
custom lower control arm
PBM nockles (angle kit)
Eky_drifter is offline   Reply With Quote
Old 07-11-2011, 05:05 PM   #2
DRIFTING_SIL_EIGHTY
DRIFTING_SIL_EIGHTY is a splendid one to beholdDRIFTING_SIL_EIGHTY is a splendid one to beholdDRIFTING_SIL_EIGHTY is a splendid one to beholdDRIFTING_SIL_EIGHTY is a splendid one to beholdDRIFTING_SIL_EIGHTY is a splendid one to beholdDRIFTING_SIL_EIGHTY is a splendid one to beholdDRIFTING_SIL_EIGHTY is a splendid one to beholdDRIFTING_SIL_EIGHTY is a splendid one to beholdDRIFTING_SIL_EIGHTY is a splendid one to beholdDRIFTING_SIL_EIGHTY is a splendid one to beholdDRIFTING_SIL_EIGHTY is a splendid one to behold
Yes everything needs to be tightened/torqued down properly. Think of it as if you just put your lugnuts on hand tight. The nuts would eventually back out and cause the wheel to wobble and slide off.
DRIFTING_SIL_EIGHTY is offline   Reply With Quote
Old 07-11-2011, 05:13 PM   #3
Hywarp161
Hywarp161's Avatar
Hywarp161 is an unknown quantity at this point
Torque everything to spec and use some loctite purple or blue to hold it all in place.
Hywarp161 is offline   Reply With Quote
Old 07-12-2011, 10:52 AM   #4
Eky_drifter
thanks ill do that. and let you guys know if it helped. i got my fingers crossed hoping that is what it is!
Old 07-12-2011, 12:06 PM   #5
BNASTYs13
BNASTYs13's Avatar
Trader Rating: (50)
BNASTYs13 is an unknown quantity at this point
Feedback Score: 50 reviews
Send a message via AIM to BNASTYs13
the tension rod basically holds your whole front together. without it putting "tension" on the LCA it would flop all over the place.
BNASTYs13 is offline   Reply With Quote
