Old 11-10-2003, 01:32 AM   #1
rancid240
Trader Rating: (72)
rancid240 will become famous soon enoughrancid240 will become famous soon enoughrancid240 will become famous soon enough
Feedback Score: 72 reviews
kei office excessively bouncy
I just installed my kei office. Moved up from agx/sportlines. My problem is that the car is excessively bouncy. It is so bouncy that other drivers are noticing. It is almost embarrasing. Also if i am turning and hit a bump, the rear end will loose traction and bounce up and down, similar to when learning how to drive clutch for the first time. damper is set to two up front. I am about 1-1.5 inch lower than i was with sportlines. Will raising the ride height help the bouncy problem, or do I probably have blown dampers?
rancid240 is offline   Reply With Quote
Old 11-10-2003, 01:50 AM   #2
NZO
NZO's Avatar
NZO is an unknown quantity at this point
Send a message via AIM to NZO
Have you tried setting them stiffer?
NZO is offline   Reply With Quote
Old 11-10-2003, 01:57 AM   #3
Bbandit
Bbandit's Avatar
Bbandit is an unknown quantity at this point
Send a message via ICQ to Bbandit Send a message via AIM to Bbandit
did you buy the coilovers new or used??
either way.. turn the damper level up to max and see what happens.. if its still bouncy.. maybe the shocks are blown or maybe thats just the way it is
==>>TGL GARAGE<<==.. RIP!
S13 coupe KA-T @ 0.5 Bar = SOLD!
A31 Cefiro + SR = Current
Bbandit is offline   Reply With Quote
Old 11-10-2003, 02:00 AM   #4
rancid240
Trader Rating: (72)
used, traded the agx + 3 bills. Rear are non dampening adjustable and the rate is 9/7kg.
Old 11-10-2003, 02:44 AM   #5
SlideStar
SlideStar's Avatar
SlideStar is an unknown quantity at this point
Re: kei office excessively bouncy
Well decreasing the shock rebound will give you more traction.
If you can try different spring rates, then decrease the rear.
SlideStar is offline   Reply With Quote
Old 11-10-2003, 07:34 AM   #6
sykikchimp
WOW addicted
sykikchimp's Avatar
sounds like blown dampers. even on the lowest setting, the spring should only ocilate one time. 9/7 is pretty friggin high spring rate too.. I'm going to be moving from 8/6 to 7/5 pretty soon because the 8/6 is a bit rough on certain roads.
Old 11-10-2003, 09:28 AM   #7
Dousan_PG
Dousan_PG's Avatar
sounds blown
those are old kei office model and as i told you in PM and email i think, i dont know much about them.
Aaron
Pink GodziRa
Old 11-10-2003, 03:32 PM   #8
rancid240
Trader Rating: (72)
Its oscillating about 1-3 times per bump...
Its not the harshness that bugs, just the bouncy bouncy bouncy. I took it up and down the 5 from anaheim to LA which is pretty much the most ghetto freeway in the world, it wasnt TOO bad, so its still manageable. Damn car handles like its on rails now (if i dont hit any bumps)
