Feeler/FS: 1991 e34 BMW M5!
E34 m5 Track/street car
Doing a quick feeler... I found a car I want for a daily so trying to see if there is quick interest in this. If I don't have a deposit on it in a couple of days ill just keep it. This is kind of out of the blue lol. Mods - d'sylvia chip Carbon Racing Dynamics intake Schrick 280 cam cats and rear muffler replaced with straight pipe custom headers - carbon fiber hood clear corners euro taillights - Rear seats taken out uuc evoiii ss+dssr corbeau bucket seats Greddy Oil pressure Gauge - dinan sway bars custom spring rate suspension 980lbs in front and 700 in the rear. bilstein shocks. new top hats front and rear. OEM M6 wheels with 225/255 tires (wheels retail $1200 ea!!!!!) 200k body, engine 70k Miles since rebuild WITH receipt and spec sheets.. Maintatnce: Replaced Alternator Replaced Vacuum lines Replaced PCV hose MAF rebuilt/improved TB's synchronized Cap and rotor replaced Valves Adjusted S50 Timing Chain Tensioner Rx7 FC Oil Cooler New Battery New Front Shock Mounts New Valve Cover Gasket New O2 Sensor ZHP Shift knob New UUC Brake Lines New oem rotors New Pads New thermostate New oem clutch 2k miles New front control arms. Oem refinished Valve Cover Lightened flywheel Rebuilt transmission apline head unit always used lubro moly 10w-60 Can be driven to the track Can be driven at the track Can be driven to your woman’s place Can be driven to go grocery shopping Can be driven to your other woman's place. Negative: small dent on passenger fender cluster back light flickered on/off now won't come on. (either wire or bulbs...will try and fix it) Front signals not wired in. (pretty easy to do, was never cared for as car was tracked) I have about 150-200 maintenance records for this car. Driving around town gets 20-22mpg if you don't get on it. Aggressive driving usually averages to 17-18mpg for me. This thing SCREAMS when u get on it. The ITB's combined with this exhaust work perfect with each other. 1 track event on this car at Autobahn and it drove great. No problems whatsoever. $8000 OBO ![]() ![]() ![]() ![]() ![]() ![]() |
