Old 07-20-2011, 07:56 AM   #1
NismoR003
NismoR003's Avatar
NismoR003 is an unknown quantity at this point
how to start my SR after a year? looking for good ideas
hey guys, am coming back from deployment soon, and i need to start my s15 motor, its been sitting in a storage for about a year, do you guys have any ideas, i though about taking off the valve cover squirt oil on the top end, squirt oil in the pistons, change oil of course, any other ideas, I am trying to make this as smooth as i can, thanks guys
NismoR003 is offline   Reply With Quote
Old 07-20-2011, 08:26 AM   #2
mewantkouki
Trader Rating: (36)
mewantkouki will become famous soon enoughmewantkouki will become famous soon enoughmewantkouki will become famous soon enough
Feedback Score: 36 reviews
Check oil level, unplug coilpack harness, crank motor for 15 seconds, repeat 2 or 3 times, check oil level again, start.
mewantkouki is offline   Reply With Quote
Old 07-20-2011, 03:17 PM   #3
jr_ss
I would unplug the CAS, not just the coil pack harness. If you just unplug the coilpack harness your injectors can still fire... Crank several times with the CAS unplugged first to get some oil pressure built up, then plug in and start it up.
Change all filters, fluids, and spark plugs before firing it up, just as precautionary items. Fuel and oils break down after not being used and exposed to air...
Old 07-20-2011, 06:18 PM   #4
240sohc
240sohc's Avatar
240sohc is an unknown quantity at this point
fuel stabilizer should help out for gas thats been stored for long time.
240sohc is offline   Reply With Quote
Old 07-21-2011, 05:49 AM   #5
NismoR003
NismoR003's Avatar
thanks guys good tips, god i cant wait to get home and start my baby up, I just need to hear the sound of an SR, tired of hearing diesel engines all day long.
Old 07-21-2011, 05:59 AM   #6
Toi
Toi is an unknown quantity at this point
I would definitely change the oil, moisture will build up while your gone, its best to just go ahead and change it out along with the filter.
An oil flush wouldn't hurt things either, pretty simple.
Toi is offline   Reply With Quote
Old 07-21-2011, 01:24 PM   #7
change
change is on a distinguished road
while the valve cover is off crank it with the CAS unplugged until oil comes out of the tubes that run along and oil the cams. that way you know it has oil pressure everywhere.
change is offline   Reply With Quote
Old 07-21-2011, 03:34 PM   #8
Def
Change oil, crank it to build pressure, spray WD-40 in all spark plug holes before you do this (it's a great top end lube), and I'd even crank the engine with the plugs out just to let it really build oil pressure without a load on the bottom end.
I hope you put some stabilizer in the gas.
DEFSPORT
Old 07-22-2011, 02:24 AM   #9
bladetech8
bladetech8's Avatar
Trader Rating: (32)
bladetech8 is an unknown quantity at this point
Feedback Score: 32 reviews
I guess I would also unplug the fuel pump main fuse to preventing flooding the cylinders with fuel when trying to build oil pressure.. Not sure if unplugging the CAS causes the ECU to not dump fuel.. If that is so, then I guess unplugging the fuel pump main fuse is not necessary.
Also, I don't think you need to remove the valve cover at all.. Just crank motor with CAS unplugged (and fuel pump main fuse if necessary) until Oil Pressure Dummy Light comes off and stays off for a least 3-5 cranking revolutions..
Like mentioned above, definitely change oil/oil filter and add some fuel stabilizer into the gas tank before trying anything..
Good luck and welcome back!
bladetech8 is offline   Reply With Quote
Old 07-22-2011, 03:13 AM   #10
Vernal
Vernal is not welcome here anymoreVernal is not welcome here anymoreVernal is not welcome here anymoreVernal is not welcome here anymoreVernal is not welcome here anymoreVernal is not welcome here anymoreVernal is not welcome here anymoreVernal is not welcome here anymoreVernal is not welcome here anymore
Send a message via AIM to Vernal
slow warm up
Vernal is offline   Reply With Quote
Old 07-22-2011, 07:25 AM   #11
bb4_96
bb4_96 is an unknown quantity at this point
I imagine you'll be pretty tired of the near beer so after you do your preliminaries start it up grab a lawn chair and drink beer. Let it warm up before you get on it. Don't sit in it while it's warming up or you'll be too tempted.
bb4_96 is offline   Reply With Quote
Old 07-22-2011, 03:31 PM   #12
Tantwoforty
Tantwoforty's Avatar
Tantwoforty is an unknown quantity at this point
just cut the fuel and spark and make oil pressure, and start it and let it warm up
Tantwoforty is offline   Reply With Quote
Old 07-22-2011, 04:03 PM   #13
jr_ss
Guys, unplugging the CAS kills spark and fuel... If the ECU doesn't see a signal from the CAS, it doesn't fire the coils or injectors.
