Old 11-10-2003, 05:01 PM   #1
ICKY
Account Closed
ICKY is an unknown quantity at this point
Send a message via AIM to ICKY
s14 Revs
I have an 95 s14 and im keeping my ka and turbocharging it, i just wanted to know what i can do to give me alittle higher rev limit. i plan on drifting the car too
ICKY is offline   Reply With Quote
Old 11-10-2003, 05:31 PM   #2
JasonNagra
JasonNagra is an unknown quantity at this point
Send a message via AIM to JasonNagra
You can have the rev limiter removed by a tuning company that does ECU work (Jim Wolf). In terms of safely increasing the redline you would have to get into engine internals...
What does increasing redlin ehave to do with drifting?
http://www.imagestation.com/picture/...f/f9dc7664.jpg
Edit: check your link.
JasonNagra is offline   Reply With Quote
Old 11-10-2003, 05:46 PM   #3
AceInHole
Autox Technician
AceInHole's Avatar
AceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfection
helps you spin out without having to change gears
AceInHole is offline   Reply With Quote
Old 11-10-2003, 06:26 PM   #4
JasonNagra
Oh okay, thanks for clearing that up!
Old 11-10-2003, 07:03 PM   #5
matlock
matlock is an unknown quantity at this point
I guess I was unclear on what having a higher rev lets you achieve in drift? I guess now I know!
matlock is offline   Reply With Quote
Old 11-10-2003, 07:08 PM   #6
deviousKA
deviousKA's Avatar
deviousKA is making a name for him/her selfdeviousKA is making a name for him/her self
Send a message via AIM to deviousKA
you can destroke it and/or get a fully counterbalanced crankshaft. That is if you want to raise your rev limit significantly. Although this may be overkill for most people.
deviousKA is offline   Reply With Quote
Old 11-10-2003, 09:43 PM   #7
cdlong
i think the valve springs would be the first thing to up grade.
cdlong is offline   Reply With Quote
Old 11-10-2003, 09:45 PM   #8
AceInHole
Autox Technician
AceInHole's Avatar
cams would be the first thing i'd get.
Old 11-11-2003, 08:42 AM   #9
cdlong
you could use stock cams up to a higher rev limit, but you wouldn't get much gain with them. if you don't upgrade the valve springs you'll start floating valves and ruin your engine.
if you only want to hit 7500 or 8000 rpm you would probably be fine just upgrading the cams and valve springs.
