Old 11-24-2011, 10:07 AM   #1
RED_P1LL
RED_P1LL is an unknown quantity at this point
Horsepower numbers help!!
Brian crower 272 cams
CP pistons
Eagle rods
ARP hardware and head studs
Cosworth metal head gasket
Brian crower springs and retainers
Z32 maf
Greddy intercooler
Garrett gt3076r
SSQV blow off valve
JGY fuel rail
680cc top feed injectors from JE
E-manage ultimate fully tuned
Ok with this mod list what kinda horsepower should I look for? I'm hoping in the 400 range but what do you guys think???
RED_P1LL is offline   Reply With Quote
Old 11-24-2011, 10:12 AM   #2
anthonyr sil8ty
anthonyr sil8ty is an unknown quantity at this point
pump gas, you should be in the low 400's.
that maf and injectors, wont let you out of the 400's, didnt see a fuel pump on the list
anthonyr sil8ty is offline   Reply With Quote
Old 11-24-2011, 04:26 PM   #3
badbob2121
badbob2121's Avatar
badbob2121 is an unknown quantity at this point
Dumbass
you didnt even post what motor your reffering to..
FOLLOW ME ON INSTAGRAM = BOBBY_LS13
badbob2121 is offline   Reply With Quote
Old 11-24-2011, 04:30 PM   #4
colombianbryan
colombianbryan's Avatar
colombianbryan is an unknown quantity at this point
how many pounds are you pushing? your going to need an upgraded fuel pump, and those injectors most likely will max out if you want past 400whp
I love drifting into curbs and guardrails
colombianbryan is offline   Reply With Quote
Old 11-24-2011, 04:55 PM   #5
boms
boms's Avatar
boms is an unknown quantity at this point
SR20det | Comp 6062 | TDC Manifold - Carolina Hondas
customers car.. excuse the dyno.. tack pickup had broke that morning. but you get the idea
boms is offline   Reply With Quote
Old 11-24-2011, 05:37 PM   #6
rcdad123
rcdad123's Avatar
rcdad123 is an unknown quantity at this point
not familiar with E-manage but if it`s a complete stand alone, you should have no problems exceeding the power you want, as long as you get a fuel pump that can handle the power. i had a bone stock 2.4 dohc tacoma engine that made 360 whp and 320 torque with just 370cc Ford motorsport injectors. i had the fuel pressure set to 70 psi. 680cc is more than enough.
rcdad123 is offline   Reply With Quote
Old 11-24-2011, 07:25 PM   #7
F20cS13
F20cS13's Avatar
F20cS13 is an unknown quantity at this point
1)emanage is a piece of sht. Get something different.
2) run 1000cc injectors (injector dynamic,not RC)
3) fuel pump
4) e85 is going to make a massive difference. With that Turbo injectors and fuel, ull hit 400+ without thinking about it. That Turbo is good for 500 range
I would run a synapse bov, diaphram bov are old news
What cc of pistons? Thickness of head gasket? Little more specific would be nice
This is on a gt2860rs
1000cc injectors
E85
9:6.1 compression
Injectors rprunning at 60% duty cycle at 60psi static fuel pressure.
Honda powered s13
F20cS13 is offline   Reply With Quote
Old 11-24-2011, 08:27 PM   #8
RED_P1LL
My bad guys, it's a blacktop sr20 and yes have a walbro 255
Old 11-24-2011, 08:38 PM   #9
anthonyr sil8ty
then you have your answer
Old 11-24-2011, 09:15 PM   #10
ILoveJDM
ILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to behold
how
much
boost
DODOlogic.ca
ILoveJDM is offline   Reply With Quote
Old 11-24-2011, 09:25 PM   #11
MadScientist
MadScientist's Avatar
MadScientist is just really niceMadScientist is just really niceMadScientist is just really niceMadScientist is just really niceMadScientist is just really niceMadScientist is just really niceMadScientist is just really niceMadScientist is just really niceMadScientist is just really niceMadScientist is just really nice
injectors are to small.
agree with 1000cc injectors for 3076
the Z32 MAF will hold 500hp but converting to MAP will keep you on the road if you blow an IC pipe or have boost leak.
you can hit 400 under 20lbs if you get a damn good tune.
MadScientist is offline   Reply With Quote
Old 11-24-2011, 09:42 PM   #12
Pinggg
Pinggg's Avatar
Trader Rating: (22)
Pinggg is an unknown quantity at this point
Feedback Score: 22 reviews
3) fuel pump
1000cc injectors
E85
9:6.1 compression
What other supporting mods you have to be hitting 400hp? Cams, headwork, boost? etc
Pinggg is offline   Reply With Quote
Old 11-24-2011, 09:46 PM   #13
ILoveJDM
it takes some effort for an stock internal sr20 to make over 400whp
18+psi with cams/headgasket/head studs.
cams are the biggest thing, make or break 400whp on these motors.
DODOlogic.ca
Old 11-24-2011, 10:31 PM   #14
Boostedkouki
Boostedkouki's Avatar
Boostedkouki is making a name for him/her selfBoostedkouki is making a name for him/her self
Send a message via AIM to Boostedkouki
Only problem i see is Injectors and im not too fond of the Emanage we made 406whp on 740cc and the injectors were hating life i would say 350whp with those 680cc
Boostedkouki is offline   Reply With Quote
Old 11-25-2011, 05:33 AM   #15
F20cS13
F20cS13's Avatar
Lol key note. That is not an sr20 map
I have a Brian crower stage 3 exhaust cam.
Car makes boost at 3200rpm (8psi) and hits 12psi by red line. I also have a 2.4 stroker.
Not very familiar with sr20s but f20c don't need any head work etc for anything over 700+. A gt3076 on my current setup will give me probably close to 550-600whp. I believe you need at minimum (internally) a different headgasket for your numbers
E85 is a Huge huge help. Its basically free horsepower. Ditch the injectors as they will just hinder you down the line for future power. Your also going to need a larger injector just to support the flowrate for e85.
Honda powered s13
Old 11-25-2011, 05:39 AM   #16
F20cS13
F20cS13's Avatar
Oh the joys of vtec.....baaaAAAAAhahah
Honda powered s13
Old 11-25-2011, 12:05 PM   #17
ILoveJDM
i have nothing against your motor,
but why the fuck are you even posting in here. your motor and setup have NOTHING to do with this thread at all
youre just so boosted on your ego you have to tell the world about your swap.
what does this have to do with what hp #'s this guy is looking to make on his sr20.
do i go around saying OH THE JOYSS OF ROTARYS , posting dyno sheets of my 550whp brideported 13b, no. atleast i have owned a 400hp sr20 180sx.
GTFO.
DODOlogic.ca
Old 11-25-2011, 07:25 PM   #18
F20cS13
F20cS13's Avatar
It had nothing t do with my swap. It was a simple motor discussion about achieving his goals. And I made roughly the power he wants on my setup. It was an expkanation with my motor as an example. Get over yourself, I wouldn't care if this was a john deer motor in my car as long as it worked. So next time your little fingers start feeling an impulse to rant away because you saw the word Honda on your precious Nissan forum, get over it.
Honda powered s13
Old 11-25-2011, 07:50 PM   #19
boms
boms's Avatar
lol i think we all answered this guys question already.. you have the ability to make the hp goals you want.. let us know how it goes... end of story.
Old 11-26-2011, 11:14 AM   #20
ILoveJDM
yeah. I dont even own a Nissan anymore, but this is one of the best damn forums ever. so gtfo.
DODOlogic.ca
