![]() Join Date: Dec 2010
Trader Rating: (18)
![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 18 reviews
Two built engines (RB25det and Mazworx sleeved SR20det) and TONS OF OTHER PARTS!
1. NO BASHING PRICES OR PARTS! if you dont like it, please leave!
2. If you PM, please also bump the thread. 3. Im always adding more parts and pictures to the thread, so check back every so often. 4. More parts have been added as of...10-12-11 I don't need to sell the engines and parts, I am only doing it to speed up my other projects...so don't bother lowballing me. Mazworx SR20DET Engine- I WILL NOT PART OUT THIS SR! HEAD- New SR20DET Head- $500 Stage 2 Port and Polish- $800 Polished Combustion Chamber- $210 Full Radius Valve job- $200 Tomei Intake Cam Gear- $200 HKS Exhaust Cam Gear- $200 Tomei Solid Lifters- $280 Tomei 270 Cams- $600 Brian Crower Springs and Titanium Retainers- $220 Supertech Valves- $300 HKS Rocker Arm Stoppers- $100 SR20DET Powder Coated Valve Cover- $150 Greddy Oil Cap- $80 New Muli-layer Exhaust Gasket- $80 New Cam Angle Sensor- $330 New Rocker Arms- $150 BLOCK- SR20DET Redtop- Cost of a core block- $100 CP Pistons 86.5mm 9.0 CR- $525 Golden Eagle Sleeves- $375 Manley Turbo Tuff Rods- $725 Calico Coated ACL Race Bearings- $210 ARP Main Studs- $185 Balanced & Polished Crankshaft- $200 ATI Crank Pulley- $425 Greddy Oil Pan- $300 New Water Pump- $65 New Oil Pump- $375 Upper Oil Pan- $50 Sleeving- $280 Bore/Hone- $320 Whatever I Forgot- $X TOTAL= $8,535.00+ ASKING= $5,000 OBO if you disagree with my price, either make an offer or go have Mazworx build you the same engine and see what the price ends up being. PHOTOS: ![]() ![]() ![]() ![]() RB25DET Engine- I will part out some of this setup now, due to my friend needing some of the parts. R33 Rb25 series II~15k miles since rebuilt- $2,000 obo (just with the arp, tomei hg, and new bearings it is about 800 in parts) Arp head studs Arp main studs Tomei triple metal head gasket Greddy intake manifold w/ q45 tb- SOLD! Greddy exhaust mani ceramic coated- $850 Precision 5557 t3 t4 turbo- $650 Mcckinny mounts- $300 Rb20 trans- $200 Competition stage 4 6 puck clutch- $300 Has 4/6 spitfires that come with it- make offer Waisted spark assembly- make offer rb25 to s13 Engine Harness w/ ecu- make offer rb24 to s13 driveshaft- $250 6 370cc injectors- $150 ![]() ![]() OTHER PARTS TurboSmart Megasonic Blow Off Valve - ~1-2k miles - $150 + shipping ![]() Kisuu Custom Made Fuel Rail - NEVER USED - $150 + shipping ![]() S15 Hoods - NEVER USED - $250 ![]() ETS Custom Made Intercooler 24X8X3 - NEVER USED - PERFECT SHAPE - $175 ![]() Greddy Intake Manifold Modifide and Comes w/ Q45 (90mm) Throttle body - Roughly 500 miles - PEFRECT SHAPE - $600 Unknown Brand BOV - Slightly Used - PERFECT SHAPE - $50 ROSS TUFFBOND Water Pump Pulley -ONLY MOUNTED -PERFECT! -$100 S14 SR20 88.5mm Cometic Metal Head Gasket multilayer - NEVER USED - PERFECT SHAPE - $70 OEM SR20VE Valvetrain (IN+EX Valves, Springs, Cams, Gears) - 15,000 Miles - PERFECT! - MAKE OFFERS ON WHAT YOU NEED! S14 Non-ABS Driveshaft - Used - $120 S13 Non-ABS Driveshaft - Used - $120 S13 SR Transmision - SALE PENDING - Roughly 30k miles - PERFECT SHAPE - $150 These are all the make an offer items...i dont want or need them all so just make an offer...pictures of these upon request...its to many pictures for the thread. S13 SR OEM Coil Pack Cover BNIB SR Multi Layer Exhaust Gasket BNIB OEM SR Exhaust Gasket SR OEM Exhaust Manifold w/ Heat Shield (1) V1 Godspeed S13 Toe Arm (1) V1 Godspeed S13 Traction Rod Valve Cover Gasket Valve Cover Coil Plug Gasket Water Outlet Water Inlet (4) Cam Oil Tubes (2 Sets) (16) OEM Spring, Retainer, and Keeper (1 set) (8) SR OEM Intake Valves (1 set) (8) SR OEM Exhaust Valves (1 set) (8) SR OEM Rocker Arm (1 Set) (8) SR OEM Lifter (1 Set) SR Block (bare) w/ 87mm bore (needs align bore...roughly 200 at any machine shop) SR20 Front Cover w/ Oil Pump (2) Oil sandwich plate Galley w/ sensor (2) Upper Oil Pan (2) Water Pump Water Pump Pulley (3) Rear Crank Case Cover Crank Pulley (4) SR Oil Squirters (1 Set) (3) SR OEM Rod (4) Upper Oil Pan Screen (2 Sets) (3) Different SR20 Timing Chain Guides (3) SR Timing Chain Tensioner (2) SR Main Cap Girdle (2) Alternator Bracket AAC Valve (3) Knock Sensor (3) Coolant Tubes (2) Thermostat Housing (2) Coolant Temperature Sensor Housing 3” S14 Exhaust that was very hacked up but it has a Very good condition HKS muffler Turbo Blanket (was on a T67) SR Transmission Plate SR OEM Turbo Lines S13 Rear OEM Chamber Arm S13 Rear OEM Traction Arm S13 Rear OEM Toe Arm stock KA24de fuel pump (in working order) stock KA24de header + stock heatsheild stock KA24de airbox intake system and Filter is still clean Summit Liquid Fuel Pressure Gauge Thank You For Looking!
https://instagram.com/eck_matthew/ Last edited by Imarvin240; 10-19-2011 at 08:05 PM.. |
and it wont let me PM me...buttttttt if the rb25 is still in a running car, il trade you my running 240 s13 sohc 5speed with ksports plus cash, this way u can have another running project and i dont gotta spend my weekend swapping em lol =)
#5 | ||
Trader Rating: (18)
i had the greddy manifold modified with a larger flange welded on, but i do have a couple other Q45 throttle bodies i can sell...no flanges though.
https://instagram.com/eck_matthew/ |
Don't think I missed it, what's the mileage on the SR20 since rebuild? Willing to part block from head? If yes, PM me shipped price to 53081 for the built block.
#18 |
how much for the stage 4 clutch, ive got family in pa so i can pick up anytime
#20 |
Trader Rating: (18)
okay, im sorry, but i am getting PM'd this to much so im going to set things straight since its not clear enough above...guys, im not splitting up the SR...its staying as a complete long block (including the ati pulley). The rb25 is also staying as a complete long block. Only bolt-ons are being removed from the engine (manifolds, turbo, transmissions, ect). also, if i don't have it listed in my large list of things for sale...i probably don't have it.
https://instagram.com/eck_matthew/ Last edited by Imarvin240; 10-21-2011 at 08:12 AM.. |
#25 |
Trader Rating: (18)
guys, i have stated in enough places that the engines are not being parted out.
https://instagram.com/eck_matthew/ Last edited by Imarvin240; 10-20-2011 at 07:29 PM.. |
