Old 08-07-2011, 02:50 PM   #1
s13love-green
s13love-green's Avatar
Trader Rating: (50)
s13love-green is on a distinguished road
Feedback Score: 50 reviews
SR need local oc cali help sr experts or so
Ok just got this car in a trade it has a red top sr but has a bad idle n need help eliminating possibilities or pin piont the problem I want to ride it already so from a fellow 240 owner to another I needs ur help plz n thanks
....that what she said
s13love-green is offline   Reply With Quote
Old 08-07-2011, 02:51 PM   #2
s13love-green
Trader Rating: (50)
Its my first sr so not to familiar wit the new stuff compared to ka
Old 08-07-2011, 04:00 PM   #3
562s13
562s13 is an unknown quantity at this point
bad idle as in high or jumpy or to low...
562s13 is offline   Reply With Quote
Old 08-07-2011, 04:51 PM   #4
s13love-green
Trader Rating: (50)
High wen cold n low wen warm
Old 08-08-2011, 06:10 PM   #5
UNITEDMASTER
UNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to all
There are way to many factors that can contribute to poor idle qulity to diagnose over the internet.
But heres a suggestion remove & clean the IAC assm. Also check for vaccume leaks,Or vacume hoses done wrong. This is just a start!!!!
MR JACKSON.
UNITEDMASTER is offline   Reply With Quote
Old 08-08-2011, 08:56 PM   #6
s13love-green
Trader Rating: (50)
Thanks I will also another symtom is bogging n idle dies n car turns off unless I give it gas
Old 08-10-2011, 09:36 AM   #7
Fonix36
Fonix36's Avatar
Trader Rating: (34)
Fonix36 is just really niceFonix36 is just really niceFonix36 is just really niceFonix36 is just really niceFonix36 is just really niceFonix36 is just really niceFonix36 is just really niceFonix36 is just really nice
Feedback Score: 34 reviews
Send a message via AIM to Fonix36 Send a message via Yahoo to Fonix36
um probably cold start
DRiFT 4 A Cure!
Fonix36 is offline   Reply With Quote
Old 08-10-2011, 11:12 PM   #8
s13love-green
Trader Rating: (50)
wont go away
Old 08-10-2011, 11:33 PM   #9
mad-ass
mad-ass's Avatar
idle adjustment screw
it can be metal or gray plastic.
mess it that and see if it helps any along with above IAC.
Old 08-11-2011, 07:18 AM   #10
s13love-green
Trader Rating: (50)
coo thanks for ur time bro ill try that
Old 08-11-2011, 09:18 PM   #11
UNITEDMASTER
Yo if you still have issues,PM me your adress & I may be able to come over & check it out. Or if its drivable you can bring it by ,Im in the city of Orange. LMK
MR JACKSON.
Old 08-12-2011, 08:15 AM   #12
s13love-green
Trader Rating: (50)
Tried the idle srew n nothing also u got pm sir
Old 08-12-2011, 11:12 AM   #13
Yellow4g63
Yellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of light
Send a message via AIM to Yellow4g63
The tps could be off too, I would check the ecu for codes. Even if u don't see any on the dash it could mean it wasn't wired in. Check the tps voltage, check the timing, compression test. Did he change the fuel pump or is it still a stock KA? hope he did if not he might have been boosting high on a stock pump and run the motor lean killing the rings on the pistons.
95 240sx RB20 415whp
91 Nx2000 VVL yo
Yellow4g63 is offline   Reply With Quote
Old 08-12-2011, 01:35 PM   #14
s13love-green
Trader Rating: (50)
Me n my friend checked the ecu codes on 2 ecu one didn say one said 3 n 4 34 knock sensor? Tried replacing it n nothing also fuel pump is a walbaro
Old 08-19-2011, 11:49 AM   #15
RBMadess
RBMadess is an unknown quantity at this point
hit me up, i might be able to help you out 714-483-8563
RBMadess is offline   Reply With Quote
Old 09-07-2011, 01:06 PM   #16
RACETUNE
RACETUNE's Avatar
RACETUNE is on a distinguished road
Send a message via AIM to RACETUNE
Garage BOSO
-Garage BOSO-
-Racetune Engineering-
RACETUNE is offline   Reply With Quote
Old 09-07-2011, 09:26 PM   #17
rebornS14
rebornS14's Avatar
rebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of light
Send a message via AIM to rebornS14
if you want professional help. Koji knows his way around a SR. and its close to you.
DRIFTSPEED
Address 11082 Winners Cir., #B
Los Alamitos CA 90720
Tel 562-342-9000
Fax 562-342-9002
Email [email protected]
Business Hours Monday - Friday
10:00 am - 7:00 pm PST
rebornS14 is offline   Reply With Quote
Old 09-08-2011, 12:51 AM   #18
DataXUnknown
Trader Rating: (30)
DataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfection
Feedback Score: 30 reviews
Try the simple things first, like mentioned before, clean IAC, and clean the MAF. Any exhaust leaks? Does pumping the brake pedal make it die/bog down?
DataXUnknown is offline   Reply With Quote
Old 09-14-2011, 03:19 PM   #19
RACETUNE
RACETUNE's Avatar
Garage BOSO
115 E. Gardena Blvd. Suite #3
Gardena California 90248
(310) 715-1380
SR20DET Experts.
-Garage BOSO-
